  • To Loud
  • Member For: 13y 5m 23d
sounds like the engine mounts though. not sure what you mean by bottom engine mounts.
As far as I am aware, there are two engine mounts. They sit right at the bottom of the engine.
  • Bronze Donating Members
  • Member For: 11y 1m 27d
Change them both & only use genuine. Open the bonnet, put the car in drive & load it up against the brakes & watch how much the engine moves! try the same in reverse to check the other side. They are a consumable so don't think they will last forever
  • Member For: 14y 9m 20d
Could potentially be a few things, might be worth checking the inlet manifold gasket also. Causes horrible idle, but fine at other revs.
