Mummamia New Member 3 Member For: 6y 10m 1d Posted 31/03/18 02:51 AM Share Posted 31/03/18 02:51 AM Hi, would anything else need upgrading when putting a turbosmart 7psi internal wastegate on ? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,182 Member For: 16y 9m 20d Gender: Male Location: Melbourne Posted 31/03/18 03:32 AM Share Posted 31/03/18 03:32 AM It depends what car it's going on and what the stock boost currently is. But most likely, there'll be almost no effect to changing the actuator to a 7psi on a stock car without tuning it. Only a BA XR6T with 5-6PSI stock will possible overboost to 7psi, but the stock tune probably has margin for that small amount of overboost. It's only necessary to change the actuator if the current one can't control boost. The stock one always can and you only need to upgrade it if you're changing the tune as well which obviously has more boost. Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 7m 30d Gender: Male Location: Adelaide Posted 31/03/18 05:27 AM Share Posted 31/03/18 05:27 AM I highly never recommend fitting a Turbosmart actuator without tuning as they have a very high tendency to be set to firm even with typical installation techniques and results in big overboost situations jus sayn as all .... 2 Link to comment Share on other sites More sharing options...
