***VX*R8*** Member 202 Member For: 11y 6m 15d Gender: Male Posted 26/03/18 08:45 AM Share Posted 26/03/18 08:45 AM Does anyone know if its "do-able" or does anyone have experience changing the LHS axle/driveshaft seal with the diff in place? Car is an FG TURBO SEDAN. I recently swapped the diff in my G6ET and I believe it's now leaking from the LHS seal. I'm hoping I can get away with not dropping the cradle ? In hindsight I probably should've changed these as a precaution while the diff was out ? Thanks in advance. Link to comment https://www.fordxr6turbo.com/forum/topic/93805-diff-seal/ Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 30d Gender: Male Location: Adelaide Posted 27/03/18 01:28 AM Share Posted 27/03/18 01:28 AM Yeh anything can be done with enough patience and some fancy tools as the stub axel seal is held in by that hefty carrier that’s screwed in would need to make up a finger male pattern attached to a good 1/2 inch extension bar but definitely doable 1 Link to comment https://www.fordxr6turbo.com/forum/topic/93805-diff-seal/#findComment-1654500 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 7d Gender: Male Location: Perth Posted 27/03/18 02:50 AM Share Posted 27/03/18 02:50 AM Easily done in place, you don't actually need anything fancy as the seal is presses into the bore on the carrier. I use a seal removal tool- And a seal driver But if you are short on tools a screwdriver and an appropriate sized socket works well 1 Link to comment https://www.fordxr6turbo.com/forum/topic/93805-diff-seal/#findComment-1654507 Share on other sites More sharing options...
***VX*R8*** Member 202 Member For: 11y 6m 15d Gender: Male Posted 27/03/18 07:30 AM Author Share Posted 27/03/18 07:30 AM That's what I was hoping to hear I have a removal tool just like that and a bearing press set that should hopefully have a piece that will work to press the seal on. Thankyou ??? Link to comment https://www.fordxr6turbo.com/forum/topic/93805-diff-seal/#findComment-1654522 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 7d Gender: Male Location: Perth Posted 27/03/18 10:24 AM Share Posted 27/03/18 10:24 AM On 27/03/2018 at 7:30 AM, ***VX*R8*** said: Thankyou ??? Expand Your.......... Well Come?? 2 2 Link to comment https://www.fordxr6turbo.com/forum/topic/93805-diff-seal/#findComment-1654546 Share on other sites More sharing options...
***VX*R8*** Member 202 Member For: 11y 6m 15d Gender: Male Posted 15/04/18 01:11 PM Author Share Posted 15/04/18 01:11 PM (edited) Hahaha. I have no idea why it put question marks there. Edited 15/04/18 01:13 PM by ***VX*R8*** Link to comment https://www.fordxr6turbo.com/forum/topic/93805-diff-seal/#findComment-1655655 Share on other sites More sharing options...
Scrotus Member 156 Member For: 16y 8m 17d Gender: Male Location: Adelaide Posted 01/06/18 01:43 AM Share Posted 01/06/18 01:43 AM On 26/03/2018 at 8:45 AM, ***VX*R8*** said: I recently swapped the diff in my G6ET and I believe it's now leaking from the LHS seal. I'm hoping I can get away with not dropping the cradle ? Expand Is yours leaking from where the driveshaft connects into the left side? Mine is leaking from that area from the right driveshaft. I ordered a new seal but a bit unsure how much needs to be removed to get to this. I'm assuming, the wheel, hub, brakes ect all comes off and then by the looks of it there is a bracket locking the driveshaft in place. After undoing that bracket the driveshaft should then be able to be unscrewed? Link to comment https://www.fordxr6turbo.com/forum/topic/93805-diff-seal/#findComment-1658440 Share on other sites More sharing options...
Scrotus Member 156 Member For: 16y 8m 17d Gender: Male Location: Adelaide Posted 07/06/18 11:10 AM Share Posted 07/06/18 11:10 AM Turns out changing the seal is fairly straight forward as I though, though did take 10 hours. Link to comment https://www.fordxr6turbo.com/forum/topic/93805-diff-seal/#findComment-1658664 Share on other sites More sharing options...
Mazcati New Member 7 Member For: 5y 10m 9d Gender: Male Location: WA Posted 08/05/20 02:00 PM Share Posted 08/05/20 02:00 PM Hope you can help mate, doing this asap in a ba. Did you have to remove hubs etc and pull axles out? Link to comment https://www.fordxr6turbo.com/forum/topic/93805-diff-seal/#findComment-1694600 Share on other sites More sharing options...
Box stock T. Member 1,384 Member For: 10y 23d Posted 08/05/20 11:43 PM Share Posted 08/05/20 11:43 PM There's no way you can do diff seals without removing the axles. Everything after the seals has to be removed. Shorts shafts hubs brakes and of course the wheels. Have fun. Link to comment https://www.fordxr6turbo.com/forum/topic/93805-diff-seal/#findComment-1694602 Share on other sites More sharing options...
