Puffwagon Puff Gold Donating Members 16,297 Member For: 10y 2m 22d Gender: Male Location: South Australia Posted 23/03/18 10:27 AM Share Posted 23/03/18 10:27 AM Haha him or me? Don't worry mate, smart arses abound around here. Don't worry about it, we're all mates anyhow I'd pull the plugs and check them all. If one of them is a good bit blacker than the rest then you can try to revive it or just replace it or the lot of them. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/93794-issue-xr6t-fuel/page/2/#findComment-1654290 Share on other sites More sharing options...
Gun40t Member 98 Member For: 7y 8m 21d Posted 23/03/18 10:29 AM Author Share Posted 23/03/18 10:29 AM Him, thanks mate appreciate it. Link to comment https://www.fordxr6turbo.com/forum/topic/93794-issue-xr6t-fuel/page/2/#findComment-1654291 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 5m 24d Gender: Male Location: Perth Posted 23/03/18 10:30 AM Share Posted 23/03/18 10:30 AM Could be plugs, coils or even a dodgy injector... Link to comment https://www.fordxr6turbo.com/forum/topic/93794-issue-xr6t-fuel/page/2/#findComment-1654293 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,297 Member For: 10y 2m 22d Gender: Male Location: South Australia Posted 23/03/18 10:32 AM Share Posted 23/03/18 10:32 AM All good. See^ Link to comment https://www.fordxr6turbo.com/forum/topic/93794-issue-xr6t-fuel/page/2/#findComment-1654294 Share on other sites More sharing options...
Gun40t Member 98 Member For: 7y 8m 21d Posted 23/03/18 10:33 AM Author Share Posted 23/03/18 10:33 AM Coils are good injectors new I think maybe a plug Link to comment https://www.fordxr6turbo.com/forum/topic/93794-issue-xr6t-fuel/page/2/#findComment-1654295 Share on other sites More sharing options...
Box stock T. Member 1,384 Member For: 10y 13d Posted 29/03/18 12:47 PM Share Posted 29/03/18 12:47 PM Replacing plugs is a relatively cheap way of eliminating a possible issue. Don't forget to re-gap the plugs .7 Or Lpg plugs. As puff said buddy don't take the sh¡tz and giggles to seriously. Where all smart arse's, but generally helpful smart arses. Might be worth checking ya o2 sensor as well, mine definitely cleaned up the idle issue a fair bit. Next is the up stream sensor. Link to comment https://www.fordxr6turbo.com/forum/topic/93794-issue-xr6t-fuel/page/2/#findComment-1654686 Share on other sites More sharing options...
Gun40t Member 98 Member For: 7y 8m 21d Posted 29/03/18 07:49 PM Author Share Posted 29/03/18 07:49 PM Cheers mate whats the best way to clean the o2 sensor? Toothbrush in mineral turps or somthing Link to comment https://www.fordxr6turbo.com/forum/topic/93794-issue-xr6t-fuel/page/2/#findComment-1654692 Share on other sites More sharing options...
4321 Bronze Donating Members 257 Member For: 11y 25d Posted 29/03/18 08:25 PM Share Posted 29/03/18 08:25 PM Don't try & clean sensor just replace it with a new quality one (only the frount one not the one under the car) O2 sensors are not designed to last the life of the vehicle veiw them as a long term spark plug. While these engines have suspect coils (replace with genuine only) if it runs good on the road it does not sound spark related, as you accelerate you add more fuel and therefor need more spark to light it. If there's not enough spark at idle there's not going to be any were near enough under acceleration for it to run properly. by all means change the spark plugs (and do a comp test while your there) check or replace coils is a maintenance thing on these engines. You might just have a leaking inlet gasket or the injectors need cleaning but you have to make sure the basics are right 1 Link to comment https://www.fordxr6turbo.com/forum/topic/93794-issue-xr6t-fuel/page/2/#findComment-1654693 Share on other sites More sharing options...
Gun40t Member 98 Member For: 7y 8m 21d Posted 29/03/18 08:35 PM Author Share Posted 29/03/18 08:35 PM Thanks bud for taking the time to do that. Yeah im definatly guna buy a new one today and put her in. Also while ive got your attention, if the p/steering pump has a leak, does it constantly whine under ecceleration cheers I cant work out if its box related or power steering might try the good old hose trick to listen for nose Link to comment https://www.fordxr6turbo.com/forum/topic/93794-issue-xr6t-fuel/page/2/#findComment-1654694 Share on other sites More sharing options...
BarraT Member 34 Member For: 5y 3m Posted 01/04/24 10:36 AM Share Posted 01/04/24 10:36 AM Hi, how did you go to sort out the bad idle, Please post your solution to the problem for us in the future, thank you heaps Link to comment https://www.fordxr6turbo.com/forum/topic/93794-issue-xr6t-fuel/page/2/#findComment-1722612 Share on other sites More sharing options...
