Red Tonner New Member 7 Member For: 6y 11m 11d Posted 14/03/18 08:25 AM Share Posted 14/03/18 08:25 AM The disks look like they glaze up .it looses brake pedal even after using them hard only once .from 200 klm down to 100 klm . It has all been re build only about 6000 klm ago but for some reason the pedal goes to the floor and does not pull the car up . It also has braded brake lines . I thought it was the temp under tge bonnet that cooks the master cylinder as I am flat out putting my hand on it after a track event . The other theory I have is that the master cylinder might be leaking through the seals bit I do not loose any fluid . The brakes only need to be stood on hard one time and there is nothing . I had it at a brake place but they could not fault nothing . They were to buisy at the time to look at them with a test drive . I have also flushed the brake fluid 3 times with penrite racing fluid with minimal improvment . Thinking of maybe changing pads to some bendix as I orfered them first but the brake place gave me the ebc reds instead Link to comment Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 12y 1m 24d Gender: Not Telling Posted 17/03/18 04:35 AM Share Posted 17/03/18 04:35 AM Have you checked brake booster condition / adjustment as well as the master cyl to make sure its not constantly applying the brakes ever so slightly? Link to comment Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 2m 22d Gender: Male Location: WA, Perth Posted 19/03/18 01:01 AM Share Posted 19/03/18 01:01 AM I had issues with the Bremtec pads at one stage. they glazed the rotors and caused some serious shudder from high speed braking. I had to get my rotors machined and then installed the Bendix ultimate to help get the rotors true again. I would suggest trying out the the Bendix ultimate(very dusty brake pads, drove me mad) or you could try the Project MU HC800(racing) brake pads. http://www.project-mu.com.au/en/products/pad_hcplus.php No I am not their rep and no I do not get any commission. Link to comment Share on other sites More sharing options...
