  • Bronze Donating Members
  • Member For: 11y 2m 3d
the length is the same as your old 221- the engine mounts even bolt on! (this was done so the barra could go down the same production line as the old 221/250 engines & fit their jigs for machining)
  • Member For: 11y 8m 2d
  On 13/09/2018 at 5:58 AM, GreaseGirl said:
As another American plotting a Barra swap, thank you all! I’ve been searching for those measurements. Wanting to drop into my ‘55 Studebaker.
@Mustangman570 you may need to sell one of your imports to me :) Let’s talk!
Expand
I just sent you a message on here. If for some reason you don't get it you can contact me through this facebook page https://www.facebook.com/NievesSpeedShop/?modal=admin_todo_tour
  • 1 month later...
  • New Member
  • Member For: 6y 7m 2d
a lot of people swap the 5.4 valve springs but the best bet is either crow cams valve springs or Spool industries, spool also have forged cranks, rods, pistons, valve springs, oil pump gears, heads studs, main studs & billet main caps for high boost make sure you O ring the block & head
