  • Dropping a turd
  • Member For: 17y 5m 22d
  On 03/03/2018 at 7:30 AM, joffa1 said:
I did bottom out the car car a little while ago on an unknown road but not sure if that’s got anything to do with it as no visible damage under there.
Expand
It could be the joint between the front pipe and the dump
Edited by arronm
  • Member For: 7y 9m 6d
Ok I might get another chance to investigate on the weekend so will check that too.  Went past my exhaust guy this arvo and he had a quick listen with his stethoscope and confirmed around the turbo/dump area, but I already knew that!
Said he will have to do some dismantling to find it and car was too hot to work on so will have to drop it off one night next week so he can look at it the next day.
It continues...
  • Puff
  • Member For: 10y 2m 20d
May as well chuck a gen 2 gtx on there if you've got the turbo off ay? :stirthepot:
I wish... bike build taking up all the funds at the moment.
When she is running spot on its plenty quick in stock form... for now anyway!
if I were to have another look at this leak on the weekend and wanted to take the turbo off to free up some space is there much to it? Simply a matter of unbolting everything?
  • Puff
It's not that hard but I guess it depends on how handy you are.
You wouldn't need to change your oil after a turbo swap. You would need to top up the coolant though.
Expand
I've gotta cook dinner now but the info is on the forum here and there. If you undo it all (turbo, dump etc) and put it back together properly you will more than likely fix the leak.
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 8d
You won't spill much oil at all in removing the turbo if it's cold. The only part that drips oil is the turbo feed. Plug that up with a rag and you'll be fine. Coolant can be a pain, though... Drain it first to avoid issues. Everything else just takes a bit of care.
Realistically you shouldn't need to remove it anyway.
  • Puff
Haha but seriously you shouldn't need to take the turbo off as a first step to finding the leak.
