Puffwagon Puff Gold Donating Members 16,330 Member For: 10y 3m 3d Gender: Male Location: South Australia Posted 04/03/18 01:08 AM Share Posted 04/03/18 01:08 AM If you do take it somewhere it should be pretty easy for them to find it. You've already kinda sussed out where it is and a shop can put it on a hoist for a better look. Let us know how you get on with it anyway Link to comment https://www.fordxr6turbo.com/forum/topic/93746-can%E2%80%99t-identify-noise/page/4/#findComment-1653100 Share on other sites More sharing options...
joffa1 Member 162 Member For: 7y 9m 21d Posted 04/03/18 01:40 AM Author Share Posted 04/03/18 01:40 AM No worries will do. Thanks so much for all your help. Link to comment https://www.fordxr6turbo.com/forum/topic/93746-can%E2%80%99t-identify-noise/page/4/#findComment-1653103 Share on other sites More sharing options...
joffa1 Member 162 Member For: 7y 9m 21d Posted 04/03/18 02:47 AM Author Share Posted 04/03/18 02:47 AM Actually just by pure accident I was degreasing and sprayed a little water down there to get it off and upon starting motor again noticed some bubbles coming up here (I guess that is the turbo to manifold connection - the one with the 4 bolts and exposed thread at the end). So I’m thinking this must be the issue. Any advice on how to get to that front right bottom fastener - even if I can get a spanner in there there is zero room to swing it... http://s345.photobucket.com/user/Soindrift69/media/7FB94A7B-A3CC-4C29-B6D7-64F093FE79AA_zpsuptuxmpi.jpeg.html?filters[user]=147109463&filters[recent]=1&sort=1&o=0 Link to comment https://www.fordxr6turbo.com/forum/topic/93746-can%E2%80%99t-identify-noise/page/4/#findComment-1653118 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,330 Member For: 10y 3m 3d Gender: Male Location: South Australia Posted 04/03/18 02:50 AM Share Posted 04/03/18 02:50 AM It's been a while since mine was stock (I can use a spanner on them all now) but I recall using a socket and various extensions with a woobly bit and going from underneath the car. Link to comment https://www.fordxr6turbo.com/forum/topic/93746-can%E2%80%99t-identify-noise/page/4/#findComment-1653121 Share on other sites More sharing options...
joffa1 Member 162 Member For: 7y 9m 21d Posted 04/03/18 02:54 AM Author Share Posted 04/03/18 02:54 AM Yeah fair enough... don’t have a wobble bar but might pick one up during the week and hopefully I can get to it. Do do you remember are they 13mm? Link to comment https://www.fordxr6turbo.com/forum/topic/93746-can%E2%80%99t-identify-noise/page/4/#findComment-1653123 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,465 Member For: 17y 23d Gender: Male Location: Melbourne Posted 04/03/18 02:55 AM Share Posted 04/03/18 02:55 AM Puff is correct. You attack it from underneath with a short-ish socket extension bar and a wobble joint. It's tricky, but do-able. It's a 14mm nut. The one that's hardest to get to is the one that always comes loose over time. Link to comment https://www.fordxr6turbo.com/forum/topic/93746-can%E2%80%99t-identify-noise/page/4/#findComment-1653124 Share on other sites More sharing options...
joffa1 Member 162 Member For: 7y 9m 21d Posted 04/03/18 03:02 AM Author Share Posted 04/03/18 03:02 AM Ok thanks. Link to comment https://www.fordxr6turbo.com/forum/topic/93746-can%E2%80%99t-identify-noise/page/4/#findComment-1653126 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,330 Member For: 10y 3m 3d Gender: Male Location: South Australia Posted 04/03/18 03:05 AM Share Posted 04/03/18 03:05 AM Yep they love to come loose. I do them up tight af (tighter than they should be) and they seem to stay tight for a while. You can use various types of locking washer as well. There are already threads about that on the forum that should come up with the search function. Link to comment https://www.fordxr6turbo.com/forum/topic/93746-can%E2%80%99t-identify-noise/page/4/#findComment-1653127 Share on other sites More sharing options...
joffa1 Member 162 Member For: 7y 9m 21d Posted 04/03/18 03:46 AM Author Share Posted 04/03/18 03:46 AM Ok thanks again Puffwagon. Are you in an FG? How often are you finding you have to tighten them? I can live with doing it every oil change (7500kms) but any more often than that and I may look to another fix. Link to comment https://www.fordxr6turbo.com/forum/topic/93746-can%E2%80%99t-identify-noise/page/4/#findComment-1653144 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,465 Member For: 17y 23d Gender: Male Location: Melbourne Posted 04/03/18 03:52 AM Share Posted 04/03/18 03:52 AM Every oil change will be plenty often enough. He's in a BF, but the problem happens across all turbo 6 falcons. Link to comment https://www.fordxr6turbo.com/forum/topic/93746-can%E2%80%99t-identify-noise/page/4/#findComment-1653146 Share on other sites More sharing options...
