  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 23d
You often can't see the cracks in a turbine housing from the mounted-in-the-car position. The only way to be sure of it is to take the turbo off completely and remove the turbine housing and inspect it under strong lighting conditions to spot the potential problem.
  • Member For: 10y 10d
I thought the issue of the studs and nuts joining the exhaust manifold to the turbine housing working loose was common even from new? That is, can be a problem even without the housing being cracked?
  • Dropping a turd
  • Member For: 17y 6m 6d
Maybe OP can take an image of which bolts were loose or missing .  Because I think there maybe some confusion.
  • Site Developer
Expand
Yep. That is common enough that it needs to be maintained at service intervals. If yours stays without aftermarket assistance, you'll be one of the rare ones and you can think yourself lucky.
So far so good, but if they work loose more than once a year I'll probably look at aftermarket solutions!
  • Member For: 7y 9m 20d
I’m actually not sure which two bolts they replaced in the end... might have a poke around on the weekend as I imagine they would look newer than all existing bolts.
Im keen to know precisely too so I can keep an eye on them and tighten every oil change or so.
All I know is that they were apparently “turbo housing bolts” and that the turbo oil and water lines were removed to get access to them.
Haha sorry mate just being stupid. Bit of a joke around here that any problem can be traced back to diff bushes.
  • Puff
  • Member For: 10y 3m 3d
So that's why my boys are being buttheads...Lucky I still have my diff bush tool :mosking:
