  • ...JD TUNING ADELAIDE...
  • Member For: 16y 10m 11d
Hahaha no one except QLD talks HP anymore
I see whats happened ;)
  • Member For: 10y 4m 21d
well im limited now to my rear housing so the plan is to get a 1.15 ar in the future then more boost. still got 15% in the injectors but I reckon id replace them. its a journal bearing mate
im not to concerned about the high reving its a big motor so 6k is plenty. with a new 1.15ar rear housing and 30+ boost itll prolly go low 900s
  • Dropping a turd
  • Member For: 17y 5m 15d
There is a lot of power to be had from from 6000 - 6500-7000rpm from a built engine.
  • XR50T
  • Member For: 11y 11m 10d
  On 10/02/2018 at 6:20 AM, arronm said:
There is a lot of power to be had from from 6000 - 6500-9000rpm from a built engine.
FTFY
  • Puff
  • Member For: 10y 2m 13d
The power is there and along with it comes a lot more engine wear. This is the joy of an undersquare engine.
If anyone is interested, look up a piston speed calculator and see what our engines do.
  • Member For: 11y 6m 12d
You'll love some extra rpm with the manual. Mine at 6k limiter is sh*t allways smashing it and ends up hitting it at 3/4 track at the drags. I lifted it to 7000rpm at drags and never turned it back would go higher but stock motor so don't wanna get to gready. If I had a built motor in it then it would be set at 8000rpm.. more revs the better.
Any plans to run this at the plex some time? Would be keen to come see how it goes.
  • skids
  • Member For: 12y 3m 14d
  • Gender: Not Telling
all these powerful falcons making me horny.
in reality though, gotta keep up with all the 500KW SC holdens out there.....
