polishboi.luke Member 89 Member For: 10y 4m 10d Gender: Male Location: Perth w.a Posted 26/01/18 06:11 PM Share Posted 26/01/18 06:11 PM heya all after running 585 at the wheels through my btr 4 speed I decided its time to get a more serious gearbox and actually get my setup working. this weekend ive just done a t56 conversion. fitted an xtrreme twin plate, malwood short shifter, malwood heavy duty ally master cylinder and clutch hose. I just gotta change my centre bearing as the donor had a different tailshaft centre bearing.I must say its a very straight forward conversion even in regards to modifying the auto harness for start and reverse lights. the car is due to be tuned in the next coming weeks. expecting around 700-800rwhp on 24-28psi. 2002 Ba XR6 Turbo 320rwkw @16psi (old tune) 437rwkw @22psi 1263nm of torque (current) T56 Conversion tune coming soon CrowCam Heavy Duty Valve Springs and Retainers Mahle Forged Pistons (20" Oversize) Scat Forged H beam Rods Billet Oil Pump gears ACL Race series bearings MLSR Head Gasket ARP Head Studs Precision 6766 1.00AR 6Boost Hightmount Manifold Bosch 1600ccc Injectors Plazmaman 044 Twin Surge Tank Plazmaman Fuel Rail Turbosmart 2000 Fuel Pressure regulator Plazmaman Plenum Custom intercooler piping Turbo Smart 50mm External Wastegate 6Boost High mount manifold Freshly setup head including new valve steam oil seals, valve guides etc Battery relocation to rear Plazmaman 1200hp tube and fin intercooler Plazmaman full intercooler piping Plazmaman cold air intake 52mm Heavy Duty Alloy Radiator Custom Dump pipe Xforce 3.5inch hiflow cat stainless Xforce 3.5inch cat back stainless Walbro intake fuel pump Sct x3 flash tuner Tremec T56 Xtreme race series twin plate Malwood ulimate short shifter Malwood heavy duty ally master cylinder Malwood braided clutch hose Whiteline 30mm adjustable sway bar with adjustable links Whiteline 22mm adjustable sway bar with adjustable links Xzy super sport coilovers Nolathane differential bushes 4.11 Diff Gears Fullspool diff center Protex street slotted and cross drilled front rotors Protex street slotted and cross drilled rear rotors Trw pads all round King wheel evolve 20x8.5 front 20x10 rear 225x35x20 front 275x35x20 rear 20% window tint Dewinged 8000k hid kit Alpine cda137ebt head unit Alpine mrf600 4 channel Alpine mrx m240 monoblock 2 x Rockford Fosgate T2D212 Soundstream 40 FARAD capacitor Sound stream ported box Stinger 0 gauge wiring Rockford fosgate T3169S Rockford fosgate T169 5 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,358 Member For: 16y 11m 22d Gender: Male Location: Melbourne Posted 26/01/18 10:50 PM Share Posted 26/01/18 10:50 PM sweet lookin' vehicle, buddy nice work on the manual conversion now it'll be slower, but more fun to drive. Link to comment Share on other sites More sharing options...
polishboi.luke Member 89 Member For: 10y 4m 10d Gender: Male Location: Perth w.a Posted 27/01/18 07:54 AM Author Share Posted 27/01/18 07:54 AM thanks mate helps being a mechanic haha it shouldnt be slower haha itll certainly be laggier etc but should come on hard Link to comment Share on other sites More sharing options...
polishboi.luke Member 89 Member For: 10y 4m 10d Gender: Male Location: Perth w.a Posted 07/02/18 08:16 AM Author Share Posted 07/02/18 08:16 AM Got it tuned today by monsta torque made 590.6rwkw at 25psi 1 Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 1d Gender: Male Location: Adelaide Posted 07/02/18 08:24 AM Share Posted 07/02/18 08:24 AM Nice numbers mate got a Graph ? Link to comment Share on other sites More sharing options...
polishboi.luke Member 89 Member For: 10y 4m 10d Gender: Male Location: Perth w.a Posted 07/02/18 08:27 AM Author Share Posted 07/02/18 08:27 AM Sure do Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 1d Gender: Male Location: Adelaide Posted 07/02/18 08:31 AM Share Posted 07/02/18 08:31 AM The Precision is going well, that 430 graph previous was a tryre frying set up though did you havea graph for the 500 plus and the BTR ? Link to comment Share on other sites More sharing options...
polishboi.luke Member 89 Member For: 10y 4m 10d Gender: Male Location: Perth w.a Posted 07/02/18 08:33 AM Author Share Posted 07/02/18 08:33 AM Should be up there I made 437rwkw with the btr now I'm running a t56 Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 1d Gender: Male Location: Adelaide Posted 07/02/18 08:35 AM Share Posted 07/02/18 08:35 AM Yeh the opening line says 585 through the BTR though Link to comment Share on other sites More sharing options...
polishboi.luke Member 89 Member For: 10y 4m 10d Gender: Male Location: Perth w.a Posted 07/02/18 08:36 AM Author Share Posted 07/02/18 08:36 AM Yeh the dyno graph up to at the beginning of post is with the btr the new graph is with a t56 585rwhp not kW btw through the btr Link to comment Share on other sites More sharing options...
