  • FREAKY
  • Member For: 15y 5m 10d
mums camry foot almost to the floor before it grips, its just a soft pedal feel same with my corolla.
jump in my ute with factory setup still, I almost smack my head when I brake.
so I def like the initial bite gives reassurance ey haha
  • To Loud
  • Member For: 13y 6m 5d
I agree with @Rab in regards to the brake fluid @Lennox. did you get dot 4 brake fluid? you most probably did as I went through the same thing at the RAC tuning session.
Need to get dot 5 brake fluid if you plan to take it to the track.
I got my brake fluid replaced a month later and all was fine with the car.
  • Member For: 12y 3m 9d
Fmd...
Penrite racing brake fluid as mentioned above, freshly changed the day before by the mechanic.
This was months ago, I can't remember a play by play of what happened to the car, I just remember brakes not working well and lots of smoke, the pedal still worked just required more pressure.
All I know is that I won't be buying them again, I wouldn't recommend them to anyone else to use on the track, if you guys want to use them on the track go for it. I won't.
