Ba xr6 turbo engine oil cooler kits
Hezabot
  • Dropping a turd
  • Member For: 17y 3m 22d
Both process west surge tanks mount in the same location. Cooler will fit in front like my BA.
It has a fan which turns on at 80c. My sandwich plate has an 80c thermostat so the oil is not cooled under that temp.
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 10m 8d
the sandwich plate, which goes between the oil filter and the engine to divert the oil through the cooler before it goes into the filter (or after it goes through the filter, depending on orientation), has a thermostat built into it which measures the temperature of the oil as it goes to the cooler and only has the fan switched on when the oil is above a set temperature on the sensor.
  • Dropping a turd
I didnt use the PWR kit , I copied it with a B & M cooler.
This is the sandwich plate to use. Part 25782.  I used the same on my territory but mounted the cooler is the grill (no fan)
https://derale.com/products/filtration/engine2013-10-28-09-53-27459934969/sandwich-adapters/standard-engine-spin-on-adapter-with-1-2-npt-ports-22x1-5mm-filter-thread-detail
I used this cooler on the territory. You could use similar and install it in the same location as the Nizpro BF.
https://www.aeroflowperformance.com/af72-4019
  • Dropping a turd
Oil pressure gauge sender can come off turbo oil line as in F6. Its a good adapter for oil temp the one you got.
You can see the location of the oil pressure sender unit in post 4
You have to use a external thermostat now.  Also 400 series push on hose is way easier to use than what you bought.
https://derale.com/products/fluid-coolers/thermostats-1/fluid-control-thermostats/12-high-output-single-rad-pusher-pullerfan-with-standard-mount-kit-detail
Edited by arronm
  • Dropping a turd
  • 4 years later...
  • Member For: 3y 6m 25d
Sorry to dig up an old thread. But the original OEM engine oil cooler, does it have a inlet and outlet? Or will it flow either way? I removed the transmission heat exchanger and need to plumb in the engine heat exchanger to the water lines.
