  • Member For: 7y 10m 30d
Hi guys want to bleed my clutch and run some new fluid on the weekend. Anyone know what size plastic tubing I need to fit nicely over the bleeder so I don’t end up with fluid in the bellhousing? (fg MKII Tr6060 standard clutch).
Thanks.
https://www.fordxr6turbo.com/forum/topic/93577-clutch-bleeding/
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 2m 1d
Unfortunately the bleeder is in such a :pooh: spot that you're going to get fluid everywhere unless you already have a remote bleeder installed.
  • Site Developer
they either don't do it at all (which is basically what the service manual recommends, as it 'bleeds itself' via gravity bleeding, apparently)... or they have a specialised tool :icon_ford:
  • XR50T
  • Member For: 12y 1m 10d
Worst design ever that bleeder.
Well worth fitting the remote bleed kit if your likely to bleed it yourself later on.
You can kinda bleed it by emptying the reservoir and refilling it with clean fluid, would take hours to get it clean and probably a have to press the clutch a million times.
  • Site Developer
only if you're going to be removing the gearbox at time of purchase... because you need to have the gearbox out to install the remote bleeder.
