Unwanted turbo flutter
Brendo0161
  • New Member
  • Member For: 7y 4m 21d
Hey,
I have a BA mk2 turbo and I noticed about a month ago the turbo was fluttering when I drove it hard. The car HAD just the factory diverter valve installed. So I assumed this was on the way out (being a 2004 car) and I bought an atmospheric BOV for the sound and to hopefully stop the fluttering.
The BOV is nothing special, just a $40 one off eBay that said it was compatible with my car. I put it on yesterday and no matter how I adjust the spring, under high boost, the turbo will flutter. This is the part that confuses me when I sit at 1700 revs I can hear the BOV is open no matter how stiff or soft the spring is but then I also assume it isn't opening enough when I come off the throttle, pushing air back into the turbo and making it flutter.
The flutter only occurs when I floor it. Otherwise the bov will vent correctly.
So I was wondering;
  • is the issue something like the bov not being wide enough?
  • did I jump the gun on assuming the turbo flutter was an issue? (I've heard some cars just do it)
  • should I try a different spring and lubricate the piston of the bov? Or just bite the bullet and get a decent one?
Any help would be appreciated, cheers
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 11m 26d
Which BOV did you buy?
You want a recirculating BOV if you want it to be as quiet as possible. If you like the psht sound of vent to air then that's fine too.
  • New Member
Expand
Sorry, should have linked it:
https://www.ebay.com.au/itm/New-Dual-Port-Blow-Off-Valve-DIRECT-BOLT-ON-XR6-Turbo-BA-BF-FG-BOV-Dump-25mm-FPR/172620426633?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
