Darrenb10 Member 35 Member For: 7y 7m 24d Posted 25/09/17 11:16 PM Share Posted 25/09/17 11:16 PM Hey guys, ive recently bought my first ford. A bf xr6t my first turbo car aswell. Im goimg im for a tune in a few weeks. Im having a bit of trouble understanding the actuator, lets just say if I buy 15psi actuator will that only allow me to go to 15psi or is the minimum boost 15psi? Link to comment https://www.fordxr6turbo.com/forum/topic/93494-need-help-with-actuatorwastegate/ Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 3m 21d Gender: Not Telling Posted 25/09/17 11:29 PM Share Posted 25/09/17 11:29 PM Click me. Link to comment https://www.fordxr6turbo.com/forum/topic/93494-need-help-with-actuatorwastegate/#findComment-1645166 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 27d Gender: Male Location: Perth Posted 25/09/17 11:34 PM Share Posted 25/09/17 11:34 PM Yes and No The rating on the actuator is technically the minimum boost you can run. However this rule of thumb assumes the wastegate is capable of flowing enough to support the base boost pressure. If you install and properly setup a 15lb actuator on a stock turbine housing/wastegate port it WILL over boost as the wastegate will not flow enough to bypass suffcient exhaust gas pressure if opening from 15lb. Rule of thumb #2 is you should run a wastegate base spring pressure of aprox 1/2 your desired boost pressure. Again this assumes sufficient wastegate efficiency, but this may not give you the best turbo response. So a well ported wastegate (or external gate) and slightly higher than 1/2 spring rate will give you better response but also flow enough to control boost. All of the above assumes your intake and exhaust are also up to the task, so without know current mods/setup and what you're planning it difficult to give a definitive answer. Link to comment https://www.fordxr6turbo.com/forum/topic/93494-need-help-with-actuatorwastegate/#findComment-1645167 Share on other sites More sharing options...
Darrenb10 Member 35 Member For: 7y 7m 24d Posted 26/09/17 06:02 AM Author Share Posted 26/09/17 06:02 AM Cheers mate, ive got plazmaman intake and cooler and will get an exhaust soon, I want about 13 or 14 psi so thanks ill keep that in mind Link to comment https://www.fordxr6turbo.com/forum/topic/93494-need-help-with-actuatorwastegate/#findComment-1645182 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 19d Gender: Male Location: Adelaide Posted 26/09/17 07:14 AM Share Posted 26/09/17 07:14 AM You'll want a genuine Garrett 8psi actuator to do that with a good pprt and flapper job Link to comment https://www.fordxr6turbo.com/forum/topic/93494-need-help-with-actuatorwastegate/#findComment-1645183 Share on other sites More sharing options...
