XR6TTUB New Member 20 Member For: 7y 4m 3d Posted 18/09/17 12:59 PM Share Posted 18/09/17 12:59 PM G'day ladies and gentlemen (Evening is more appropriate I guess loll) I've recently purchased a 2003 BA XR6T Ute Manual in Mecury Silver, first Ford I've ever owned (Correction*First Ford was a Turbo TX5 back 16 years ago). My poor XR6T recently started to develop a strange tick/knock/tapping noise, I've tried everything up my sleeves to try and rectify the problem but to no avail I've failed time and time again In the mornings with cold starts, noise is evident and loud, tap tap tap tap but when the engine hits operating temperature it really wonders off and subsides (5 out of 10 times, you wouldn't be able to hear it at all cold or hot) Car idles weird when @ operating temp,idles a little lumpy like my stage 1 cam 180sx, but more irregular (not like a misfire) Other then the symptoms above, car drives and boost's normally, Compression tested 200-205psi across all cylinders (highest was 205psi lowest was 200psi) I'm a mechanic by trade and have never come across this situation ever New Parts Fitted *New genuine ford coils *New rocker arms/Lifters (HLAS) *New fuel filter *Used working throttle body with tps *New air filter *New Garrett FG turbo *New T/B gasket *Fresh 10w60 penrite fully syn oil with Ryco z9 filter SIDENOTE: Both exhaust and intake cams have rusted pitting and spalling on lobes, more evident on 1-2 5-6 cylinders (I guess the Car had been sitting around for sometime) as I've been rocking back and forth thinking about the pitting and spalling of the cams causing excessive clearance issues maybe? (I did use a cheap digital caliper to measure a few of the lobes, some were @ least .05-.10mm bigger and smaller) I've order a new set of plugs(genuine ford) as the ones in the car now are NGK AND they are leaking (compression leaking, Noticed when hand turning engine) I'm stumped! someone help before I pull more hair out. I've attached a video in regards to the noise (engine had sat for 1-2 hours,so it isnt as loud) I will upload other video's to outline the annoying knock/ticking noise Kenny Link to comment Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 10y 10m 25d Gender: Male Location: SW Sydney Posted 18/09/17 11:33 PM Share Posted 18/09/17 11:33 PM Nothing to do with the noise but was that FG turbo from an F6 or an XR? Link to comment Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 12y 9d Gender: Not Telling Posted 18/09/17 11:42 PM Share Posted 18/09/17 11:42 PM (edited) all I can hear is a possible serpentine belt noise? can ya remove it and take a listen? a ticky noise is normal. doesn't sound horribly wrong from my perspective Edited 18/09/17 11:44 PM by skidxr6t Link to comment Share on other sites More sharing options...
MBAF Bronze Donating Members 2,156 Member For: 8y 4m 22d Posted 18/09/17 11:48 PM Share Posted 18/09/17 11:48 PM hard to tell in the vid. Have you checked your manifold bolts? they like to come loose which will also cause some noise but cant really hear much in the vid 1 Link to comment Share on other sites More sharing options...
XR6TTUB New Member 20 Member For: 7y 4m 3d Posted 19/09/17 03:35 AM Author Share Posted 19/09/17 03:35 AM Thanks for the quick replies The powersteering pump is a little noisy and ive got a new belt to put on, what ill do is remove the belt and video a cold start so the noise is a little more evident Turbo is from an FG xr6T Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 3m 14d Gender: Male Location: Perth Posted 19/09/17 06:35 AM Share Posted 19/09/17 06:35 AM Exhaust leaks. Link to comment Share on other sites More sharing options...
XR6TTUB New Member 20 Member For: 7y 4m 3d Posted 19/09/17 08:43 AM Author Share Posted 19/09/17 08:43 AM Also forgot to mention, it has new turbo to manifold gasket and exhaust manifold gasket,dump pipe gasket is also new Link to comment Share on other sites More sharing options...
XR6TTUB New Member 20 Member For: 7y 4m 3d Posted 19/09/17 10:53 AM Author Share Posted 19/09/17 10:53 AM In the mornings with cold start, it sounds like this video (another owner experiencing the same issue) I was bored after work today and took out my stethoscope to try and pinpoint the noise,front timing case is quiet,front of valve cover is quiet, intake manifold @5-6 cylinder gets a little noisier, cylinder head and valve cover @ cylinders 5-6 are most affected. Trying to narrow down the possibilities, when I first purchased the car, the turbo (compressor blades and housing were lunched) seem s like a rock or nut was in there causing damage to the blades. Now, with the turbo spinning really fast, that nut/bolt or rock would've been hacked up and went into the engine. My first possibility is damaged intake valves (if valves were shot, I wouldn't have any compression in 1 or a few cylinders) but then again it does explain the rough/misfire at idle (fine when driving) On the way home from work, I came up to my exit off the freeway and got off, sat at the traffic lights listening to the radio. Out of no where the car just misfired (about to stall) and rims jumped up again. I'm completely lost here, maybe someone out there has a recommendation for a workshop that specialises in this type of vehicle/engine, I'm located in Melbourne Victoria, out towards the western suburbs. Only issue I have is I can't make it during business hours as I start pretty early and finish 7pm, Saturdays would work aswell A few xr6 turbo owners have recommended dyno-mite, located near me aswell, anyone heard or have experiences with them? kenny Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,104 Member For: 16y 8m 27d Gender: Male Location: Melbourne Posted 19/09/17 11:09 AM Share Posted 19/09/17 11:09 AM dyno-mite is close to you and knows these engines/cars very well. Any of the victorian tuners mentioned in this thread will be sufficient to diagnose it for you, if you are willing to travel to the east of Melbourne. Link to comment Share on other sites More sharing options...
shaness8 Member 89 Member For: 15y 5m 2d Gender: Male Posted 19/09/17 12:44 PM Share Posted 19/09/17 12:44 PM Dion tunes my car I wouldn't go anywhere else. Link to comment Share on other sites More sharing options...
