discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 5m 26d Gender: Male Location: Probably above atmospheric pressure Posted 08/07/13 11:09 AM Share Posted 08/07/13 11:09 AM On 07/07/2013 at 11:59 PM, _Velocity_ said: I should have phrased that a little better. No ticking noise in mine. Was talking more about the fact I have notched up over 200,000kms. Relevant to my interests.Having said that XFT didn't mention anything when it was in for work recently. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/93477-oils-aint-oils/page/62/#findComment-1405090 Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 14y 29d Gender: Male Location: Sydney Posted 08/07/13 11:28 AM Share Posted 08/07/13 11:28 AM If you have no oil in your catch can and it doesn't use oil is that indication that the oil your using is fine? Link to comment https://www.fordxr6turbo.com/forum/topic/93477-oils-aint-oils/page/62/#findComment-1405097 Share on other sites More sharing options...
Wingnut Member 573 Member For: 16y 9m 17d Gender: Male Posted 19/08/13 09:25 AM Share Posted 19/08/13 09:25 AM So I have the 2 most extreme experiences when changing the oil in my car. First time around 6 months ago I was getting a low oil pressure warning light so I thought I would drop the oil and see how it was. Not a single drop came out, NOT ONE DROP! When I removed the oil filter I found a heap of jet black sludge. After replacing it everything was fine for quite a while. I will add though my car has steadily been using coolant for the last couple of years (around 1lt a week possibly more) and I assumed it would have been rather terminal so I hadn't paid a lot of attention to it hoping it would blow and I would have an excuse to build it.A couple of months ago it once again was showing low oil pressure so I thought maybe the same thing happened and I topped it up. A few weeks ago now the car started running like a real pig and blowing a sh*t load of smoke. Im not exaggerating when I say I couldn't see an inch out of my rear window due to the thickness of the smoke. So I garaged it for the last month to decide what I was going to do and how far I was prepared to take the next build. Having the weekend off I thought I would have a play and see what I could find. I had the car sitting for almost 3 weeks straight and noticed a huge pool of oil underneath the left front corner so I suspected maybe my oil pump or a feed line of some sort. Feeling quite motivated I decided to change the oil and what I found shocked the living sh*t out of me... That is a picture of the oil I dropped from the car and I filled that tub another 3 times. In all I filled 3 x 5lt bottles and 3 x 1lt bottles with the dirty, gritty sh*t I dropped from my engine. All up it would have been close to 19lts.... How the f*ck does that even happen and how the hell is my car still alive? After putting new 5-30w (bought some cheap Castrol assuming it would go to waste) it runs better than I would have hoped for and doesn't seem to have lost much power if any at all. Turns out the pool of oil I found was overflow from the intake that had run into the air box and flowed out the small hole in the bottom.I know using coolant in the volume it has been is probably something terminal but the fact I have it back on the road a little longer make me very happy Link to comment https://www.fordxr6turbo.com/forum/topic/93477-oils-aint-oils/page/62/#findComment-1417117 Share on other sites More sharing options...
Bonjaz Donating Members 1,841 Member For: 16y 5m 13d Gender: Male Location: CQ Posted 19/08/13 12:28 PM Share Posted 19/08/13 12:28 PM Did the 19L of oil look watery, or coolanty or transmissiony? Is it possible the Coolant or tranny fluid is leaking into the sump because that does not look like engine oil... I can't imagine a motor running well with anything but oil in the sump... Link to comment https://www.fordxr6turbo.com/forum/topic/93477-oils-aint-oils/page/62/#findComment-1417202 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 5m 26d Gender: Male Location: Probably above atmospheric pressure Posted 19/08/13 03:19 PM Share Posted 19/08/13 03:19 PM OHMYGODIs that what coolant mixed with oil and frothed around looks like? 19L, stellar effort!!! 1 Link to comment https://www.fordxr6turbo.com/forum/topic/93477-oils-aint-oils/page/62/#findComment-1417226 Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 14y 29d Gender: Male Location: Sydney Posted 19/08/13 09:28 PM Share Posted 19/08/13 09:28 PM Dafuq did I just read 2 Link to comment https://www.fordxr6turbo.com/forum/topic/93477-oils-aint-oils/page/62/#findComment-1417246 Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 21y 26d Gender: Male Location: Brisbane Posted 19/08/13 10:16 PM Share Posted 19/08/13 10:16 PM Oh dear And you're still driving it? That's one farking tough engine. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/93477-oils-aint-oils/page/62/#findComment-1417259 Share on other sites More sharing options...
BRK Member 361 Member For: 13y 5m 8d Gender: Male Location: Perth Posted 20/08/13 12:11 AM Share Posted 20/08/13 12:11 AM Wingnut - You gotta be kiddn me that you let these faults go as long as you did? Chr!st, if mine uses more than a 150ml of oil in between changes its a "please xplain" and water loss is a call to Sherlock Holmes.The fact the car actually ran is an engineering triumph for Ford. Anyway - is it rebuild time ????? Link to comment https://www.fordxr6turbo.com/forum/topic/93477-oils-aint-oils/page/62/#findComment-1417289 Share on other sites More sharing options...
BenDoCo I'm getten too old for this s**t Bronze Donating Members 4,509 Member For: 12y 1m 14d Gender: Male Location: A big bridge over a river in South Australia Posted 20/08/13 02:11 AM Share Posted 20/08/13 02:11 AM keep driving it.....you've gone this far so lets see how many k's it will do before it falls over#causeneedsrebuildanyway 2 Link to comment https://www.fordxr6turbo.com/forum/topic/93477-oils-aint-oils/page/62/#findComment-1417313 Share on other sites More sharing options...
Wingnut Member 573 Member For: 16y 9m 17d Gender: Male Posted 20/08/13 02:38 AM Share Posted 20/08/13 02:38 AM That's exactly my point!! As soon as it started using coolant I knew it was going to cost a fortune so I didn't really consider fixing it until I had to hahaI'm not a silly and I have always been so precious with my cars but I don't sweat the small stuff these days and considering I don't need a car to get around where I live I have neglected it. Drove it a bit over the last few days and it hasn't skipped a beat. I'm curious to know exactly what is wrong but that process alone is going to be expensive and time consuming so I'm not too troubled with it atm. Link to comment https://www.fordxr6turbo.com/forum/topic/93477-oils-aint-oils/page/62/#findComment-1417328 Share on other sites More sharing options...
