Oils Aint Oils <Merged Thread>
rorojoe
  • ʎǝʞuoɯ ɹoıuǝs
  • Member For: 16y 3m 25d
I rang castrol about what power level needs the 10w60 instead of 0w40 and they said unless u take the car to the track or drive like a loose cannon for extended periods of time on the street to stick with the 0w40.
There must be a reason they changed there recommendation for the f6s from 10w60 to 0w40.
Edited by JC807
  • Member For: 17y 11m 25d
10w30 is recommended by Ford for these engines in NA form.
Once you add a turbo and some boost oil temp will be a little higher, that's why ford recommends a w40 oil and you should stick with it.
If you do anything that will cause oil to be heated any further like track work, serious hill climbs, heavy towing you can maybe go up to w50, w60 would only be for extreme situations.
Remember that ford built an engine oil temperature warning light in to these things and only few have ever seen the thing come on so they can't be getting that hot to require a w60 oil.
Edited by dule
  • Italian Stig!!
  • Member For: 14y 2m 13d
I spoke to Danny at Springy Performance Castrol edge sport 10w60 is fine to use and new formula as well no troubles at all :)that's what Ford recommended too. Even got oil gauge showing fine even I'm putting my foot down.
  • Member For: 16y 4m 19d
10w 60 edge for me too. wouldn't put anything else in it because sometimes I do drive like a loose cannon
If ford changed to 0w40 then this would only apply to stock cars. Also, probably only did that to save money.
Edited by Paulie2256
  • ʎǝʞuoɯ ɹoıuǝs
its castrol who has changed their recommendation. even nulon now recommend 0w40.
  • Slippery when dry
  • Member For: 17y 8m 28d
That really sh*ts me because I sent an email to Nulon a while ago asking them for there advice with the extra power that I was running and they recommended the 15w50 which I have been running for the last 25k (just serviced it @55k with 15w50 again,do it every 5k).
I'm really over this subject how can Ford and other oils say run a 15w40 and others say a 0w40 for the same motor???
My way of thinking was with the extra power going up to the 50 wouldnt be such a stretch with the extra boost etc...
I just think that I will give the 0w40 a go on the next change to see what it is like....very confused I'm going outside to have a beer and talk to my dog about it....haha
Edited by chippa
