Please help!!!
Mrpunk
  • Member For: 7y 5m 27d
Hey all need advice please. I have a 2012 xr6t Just had my car tuned after 2nd lot of mods, 1st mods= dump, cat and tune which produced 270 rwkw. 2nd lot of mods= battery relo, cooler n pipes, 400 pump, 1000ccs, w/gate n flapper mod + 12 psi actuator, twin 2.5 catbak, braided oil line, after tune still only 270 rwkw!!!! My tuner told me that the impeller isnt big enough and cant produce enough boost/power. I want to know why or how with all these mods is my car not producing any more power??? Im absolutely baffled to be quite honest!! Is my tuner having a lend of me? Has he not tuned correctly?? Any expert advice would be greatly appreciated.
  • Member For: 14y 4m 1d
I'm certainly no expert but how can you do all that extra mods and end up with the same result unless your turbo was shot but I doubt it. Try a new tuner.
Turbo is fine
On 9/10/2017 at 8:50 PM, Wilko16 said:
Find a new tuner mate
Was it a custom tune or generic xcal tune ?
What state are you in ?
Custom dyno, im in sa, have heard alot about jetturbo
  • WOT?
  • Moderating Team
  • Member For: 11y 9m 27d
1st lot of mods were mostly the power ones.
2nd lot were mostly the support mods.
Engines are engines - turbos are turbos
Sounds low, but I'd ask the tuner more before we bad mouth him.
Yours sounds like it should be doing 300+, but there could have been something that just didn't work
My car now idles like sh*t, smells of fuel, conks out sometimes when I start it.....the only thing I have is a bit more mid range power
On 9/10/2017 at 9:03 PM, Head said:
You didn't say who tuned it?
Hes not really know but his name is graham tickner, pt adelaide auto
  • WOT?
  • Moderating Team
Ah, yep - didn't realise he was S.A. - E85 not required on the baby (FG) turbos over there to get over 330 at the rear.
That sounds more like the issue/reason to go elsewhere - have you given him a chance to fix it?
Honestly though - post up the dyno sheets - the graphs at the bottom will tell more about how farked or not the tune/tuner is than anything else.
If he didn't/won't hand them to you then I'd look for someone to fix the car before you drive it on boost.
