molch Donating Members 174 Member For: 18y 5m 14d Gender: Male Location: Central Coast Posted 20/08/17 10:29 PM Share Posted 20/08/17 10:29 PM Hi guys,, im looking at a girdle for my engine build and being on a budget every hundred I save on a component really adds up. I wanted to find out if anyone has experience with the below girdles and what power output they were putting out? Atomic - #306254 - Atomic main cap girdle - 10mm thick suit FG-on Ford 6 cyl Street application $ 495.00 Mace Engineering - 10mm Aluminium, MAIN CAP GIRDLE FORD FALCON BARRA XR6 BA BF FG FG X 4.0L 6 CYLINDER $ 350 Spool - 10mm steel. SPOOL XR6 main cap girdle - $425 Procomp Electronics - machined from 1045 steel - $250 Sonic Injection - Manufactured from 10mm Medium Carbon mild steel - $225 I am leaning towards being brand generic with this but up for advice from those with experience? Link to comment Share on other sites More sharing options...
eff xr6t Member 569 Member For: 11y 3m 15d Posted 21/08/17 05:03 AM Share Posted 21/08/17 05:03 AM Went to use a sonic on a built AU motor recently and bolt holes didn't line up properly without flexing main studs I would send them the stock girdle to ensure holes end up in the right spot if buying one. Atomic one turned up looking like a 4 year old had used the die grinder to de burr the holes with most bolt down surfaces having burr marks all over them.Want something that fits properly without worrying I would ring Jason at Tunnel Vision turbo charging. Can't comment on the others as this is all I've used other then the current one that we had laser cut from a stock girdle and then drilled the holes ourselves. Link to comment Share on other sites More sharing options...
