kainog6e New Member 10 Member For: 7y 4m 26d Posted 19/08/17 09:44 AM Share Posted 19/08/17 09:44 AM I just replaced the turbo on my g6e with a brand new one, exact same turbo but now I'm experiencing major turbo lag. Will I need to get it tuned or could something else be the issue? Link to comment Share on other sites More sharing options...
Puffwagon Trust me bro... Gold Donating Members 16,052 Member For: 9y 11m 16d Gender: Male Location: South Australia Posted 19/08/17 10:01 AM Share Posted 19/08/17 10:01 AM It wasn't installed correctly if it is the exact same turbo. Look for a gasket leaking, an intercooler fitting leaking or your wastegate being stuck open. Maybe the actuator hose isn't plumbed correctly or the boost solenoid isn't plugged in. Link to comment Share on other sites More sharing options...
kainog6e New Member 10 Member For: 7y 4m 26d Posted 19/08/17 10:17 AM Author Share Posted 19/08/17 10:17 AM Could it be the new actuator causing the issue? Would it be worth putting the old actuator back on? Link to comment Share on other sites More sharing options...
Puffwagon Trust me bro... Gold Donating Members 16,052 Member For: 9y 11m 16d Gender: Male Location: South Australia Posted 19/08/17 11:39 AM Share Posted 19/08/17 11:39 AM If it isn't adjusted correctly it could be holding the wastegate open. Link to comment Share on other sites More sharing options...
JVK Silver Donating Members 751 Member For: 19y 27d Gender: Male Location: North West Hot Hell,VIC Posted 19/08/17 09:43 PM Share Posted 19/08/17 09:43 PM ^^^whs^^^ wastegate more than likely not shut. Link to comment Share on other sites More sharing options...
kainog6e New Member 10 Member For: 7y 4m 26d Posted 20/08/17 01:30 AM Author Share Posted 20/08/17 01:30 AM Ok will put the old actuator on and see if that sorts it. Also what does the 6-1/1 number on the turbo mean? Link to comment Share on other sites More sharing options...
Puffwagon Trust me bro... Gold Donating Members 16,052 Member For: 9y 11m 16d Gender: Male Location: South Australia Posted 20/08/17 01:41 AM Share Posted 20/08/17 01:41 AM Have a read up on how the actuator works and how you adjust it before you go swapping it over. Here is the turbosmart iwg instructions. Here is a youtube clip showing how to adjust the preload. You will see that if the actuator is not adjusted properly the wastegate will not be sealed shut. Link to comment Share on other sites More sharing options...
kainog6e New Member 10 Member For: 7y 4m 26d Posted 20/08/17 02:05 AM Author Share Posted 20/08/17 02:05 AM Cheers, pretty sure it was shut when I put it on. Link to comment Share on other sites More sharing options...
kainog6e New Member 10 Member For: 7y 4m 26d Posted 20/08/17 04:00 AM Author Share Posted 20/08/17 04:00 AM Any info on what the numbers mean, the old one has 6-1/1 whereas the new one has 7-1/1 Link to comment Share on other sites More sharing options...
kainog6e New Member 10 Member For: 7y 4m 26d Posted 23/08/17 10:56 AM Author Share Posted 23/08/17 10:56 AM Lags with the old actuator on too. I did a fault scan and got the fault P1228 FORD - Wastegate Failed Open Under Pressure Link to comment Share on other sites More sharing options...
