EkooOttoman New Member 5 Member For: 7y 10m 18d Posted 26/07/17 10:14 PM Share Posted 26/07/17 10:14 PM Hi All, Still being a newbie I just had a question to ask. Are the rear shocks as simple to change as I think they are. Is it basically just remove the tire to get it out of the way, basically a nut at the top of the shock and a nut at the bottom or something along those lines ?? Instead of paying a mechanic I wanna try it myself, mates have told me its piss easy, should be a good experience for me. Link to comment https://www.fordxr6turbo.com/forum/topic/93400-xr6-fg-rear-shocks-help/ Share on other sites More sharing options...
El Andrew Gold Donating Members 2,039 Member For: 10y 1m 15d Gender: Male Location: Canberra ACT Posted 27/07/17 01:09 AM Share Posted 27/07/17 01:09 AM I've only done a BA, but yes it is a very simple job. Assuming it is the same as BA, the only trick might be to use a jack under the lower control arm to help compress the spring a little to get the lower shock bolt back in. Top mount of shock can need a little convincing too - I loosened the bolts holding the bracket to the body to help get the new shock in place then retightened. Link to comment https://www.fordxr6turbo.com/forum/topic/93400-xr6-fg-rear-shocks-help/#findComment-1642992 Share on other sites More sharing options...
