Cameron02 Member 164 Member For: 12y 4m 22d Posted 25/07/17 12:21 AM Share Posted 25/07/17 12:21 AM Hi Turboists I tried searching many times for the answer but cant find anything, I need your help The rubber intake connector from my intake pipe to the compressor housing has a hole in it. I obviously need to replace it (I guess with a silicon connector) but I cant find the sizing anywhere. I'm guessing its 4 inch on the housing down to 3.5 inch on the pipe (all stock piping on a BA). Your knowledge will save me having to pull it all apart to check and may help fellow tuboists in the future Link to comment https://www.fordxr6turbo.com/forum/topic/93397-ba-compressor-connector-size/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,460 Member For: 17y 22d Gender: Male Location: Melbourne Posted 25/07/17 12:25 AM Share Posted 25/07/17 12:25 AM it's a 3inch outlet from the stock compressor housing Link to comment https://www.fordxr6turbo.com/forum/topic/93397-ba-compressor-connector-size/#findComment-1642895 Share on other sites More sharing options...
Cameron02 Member 164 Member For: 12y 4m 22d Posted 25/07/17 05:18 AM Author Share Posted 25/07/17 05:18 AM Thanks for the reply. I am however, looking for the inlet size Link to comment https://www.fordxr6turbo.com/forum/topic/93397-ba-compressor-connector-size/#findComment-1642911 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,460 Member For: 17y 22d Gender: Male Location: Melbourne Posted 25/07/17 05:25 AM Share Posted 25/07/17 05:25 AM I'm pretty sure that it's 3 inch all the way from the outlet of the airbox to the turbo compressor inlet. It might be bigger on that flex pipe between the airbox and the crossover... it's very easy to unclip it and measure it yourself, though, to be sure. Link to comment https://www.fordxr6turbo.com/forum/topic/93397-ba-compressor-connector-size/#findComment-1642913 Share on other sites More sharing options...
Cameron02 Member 164 Member For: 12y 4m 22d Posted 25/07/17 06:13 AM Author Share Posted 25/07/17 06:13 AM No worries. Thanks The compressor inlet is definitely bigger than the pipe as the current connector changes size (steps up) Link to comment https://www.fordxr6turbo.com/forum/topic/93397-ba-compressor-connector-size/#findComment-1642914 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,460 Member For: 17y 22d Gender: Male Location: Melbourne Posted 25/07/17 06:52 AM Share Posted 25/07/17 06:52 AM I'm 100% sure that the compressor outlet is 3inch. That "s-shaped" pipe fits inside two silicone joiner pieces which are obviously slightly larger than the pipe itself. The "flex-pipe" between the crossover pipe and the airbox is the one you'll need to measure as I'm not 100% sure of the size there. Link to comment https://www.fordxr6turbo.com/forum/topic/93397-ba-compressor-connector-size/#findComment-1642916 Share on other sites More sharing options...
