Ale Member 249 Member For: 13y 2m 21d Posted 21/06/17 01:54 AM Share Posted 21/06/17 01:54 AM (edited) 2 hours ago, k31th said: or speak to Hardy Spicer and tell them your specific make/model/trans setup and they'll be able to tell you which specific one will fit. These fkrs caused me a major headache with my BF, sold me the "right " centre bearing, but I had to "make" it fit (should've sent it back) only to find the car had a slight vib at 60km/hr. After taking the car to ford for them to do their "black magic " on car balance trick it was still crap... They then took the shaft to Hard spicer here in Adelaide, where I had to pay them to put the "right" bearing on the shaft , then back to ford for more black magic. Still was wrong, so the shaft went back to Hardy only for them to admit they didn't balance it properly. Non of it was Fords fault, so I had to cough up for the 2 doses of back magic even though I highly doubt it makes any difference if the shaft is correctly assembled and balanced in the first place...fk I don't miss that B series, I had so much bad with it Edited 21/06/17 01:57 AM by Ale Link to comment Share on other sites More sharing options...
AzSilverBullet New Member 7 Member For: 7y 4m 25d Posted 21/06/17 04:27 AM Author Share Posted 21/06/17 04:27 AM 3 hours ago, Ralph Wiggum said: the bearing height is the same, manual car get a spacer between the bearing mount and chassis, auto's do not. What bearing are you looking at? Tailshaft Center Bearing. I now know I need 30mm ID coz its a uni joint shaft but not sure if need 11mm or 25mm offset center height. Go on Hardy Spicer website - Center Bearings - Ford and you will see there is 4 options for FG Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 1m 23d Gender: Male Location: Perth Posted 21/06/17 05:12 AM Share Posted 21/06/17 05:12 AM What trans do you have? Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 19d Gender: Male Location: Perth Posted 21/06/17 06:25 AM Share Posted 21/06/17 06:25 AM Measure it. The more of a straight line between the rear of the box and the diff the better. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 1m 23d Gender: Male Location: Perth Posted 21/06/17 06:58 AM Share Posted 21/06/17 06:58 AM (edited) within reason. Some Angluar disparity (3deg is the magic # apparently) prevents the uni's and cv's from wearing in the same path all the time. Edited 21/06/17 06:59 AM by Ralph Wiggum Link to comment Share on other sites More sharing options...
AzSilverBullet New Member 7 Member For: 7y 4m 25d Posted 21/06/17 07:08 AM Author Share Posted 21/06/17 07:08 AM 1 hour ago, Ralph Wiggum said: What trans do you have? ZF auto. We know that uni shaft is 30mm ID and CV shaft is 35mm ID. My best guess is that depends if u have a manual or auto as to needing 11mm or 25mm offset center height. Think I best just pull it out first and go from there.... Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 1m 23d Gender: Male Location: Perth Posted 21/06/17 08:08 AM Share Posted 21/06/17 08:08 AM ZF will use the 25mm offset. Link to comment Share on other sites More sharing options...
AzSilverBullet New Member 7 Member For: 7y 4m 25d Posted 21/06/17 12:14 PM Author Share Posted 21/06/17 12:14 PM Are you 100% sure buddy? Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 1m 23d Gender: Male Location: Perth Posted 21/06/17 12:18 PM Share Posted 21/06/17 12:18 PM 92.58% Link to comment Share on other sites More sharing options...
AzSilverBullet New Member 7 Member For: 7y 4m 25d Posted 21/06/17 12:33 PM Author Share Posted 21/06/17 12:33 PM I need atleast 98.73 haha Why do say the ZF will need 25mm? Also I wonder why Hardy Spicer only make replacement uni joint up to BF, No FG!? Link to comment Share on other sites More sharing options...
