Brendon Wrigley New Member 17 Member For: 9y 4m 26d Gender: Male Location: Rockhampton QLD Posted 09/06/17 12:36 AM Share Posted 09/06/17 12:36 AM So I've seen on facebook and various other place that people have swapped out the earlier design (prone to ball joint failure) to the redesigned MK2 deisgn. What was involved? (just bolt in or significant mods). What parts do you need off the MK2? Worth it? any other tricks to catch out new players? Cheers in advance Link to comment https://www.fordxr6turbo.com/forum/topic/93287-mk2-front-end-into-mk1-ball-joint-issue/ Share on other sites More sharing options...
burkey05 Member 76 Member For: 11y 3d Gender: Male Location: Melbourne Posted 15/06/17 02:03 AM Share Posted 15/06/17 02:03 AM you need the two front lower control arms and the hub asembly/knuckle, per side the pic below has what you need the assembly on the right is the older design with the lower control arms underneath the knuckle , on the left is the mk2 with the lower control arms "inside" the knuckle 1 Link to comment https://www.fordxr6turbo.com/forum/topic/93287-mk2-front-end-into-mk1-ball-joint-issue/#findComment-1641028 Share on other sites More sharing options...
hrick Member 210 Member For: 15y 4m 5d Posted 15/06/17 07:54 PM Share Posted 15/06/17 07:54 PM photo link not found Link to comment https://www.fordxr6turbo.com/forum/topic/93287-mk2-front-end-into-mk1-ball-joint-issue/#findComment-1641048 Share on other sites More sharing options...
burkey05 Member 76 Member For: 11y 3d Gender: Male Location: Melbourne Posted 16/06/17 12:15 AM Share Posted 16/06/17 12:15 AM sorry about that 3 Link to comment https://www.fordxr6turbo.com/forum/topic/93287-mk2-front-end-into-mk1-ball-joint-issue/#findComment-1641053 Share on other sites More sharing options...
Brendon Wrigley New Member 17 Member For: 9y 4m 26d Gender: Male Location: Rockhampton QLD Posted 19/06/17 03:28 AM Author Share Posted 19/06/17 03:28 AM cheers ben Link to comment https://www.fordxr6turbo.com/forum/topic/93287-mk2-front-end-into-mk1-ball-joint-issue/#findComment-1641218 Share on other sites More sharing options...
