shaness8 Member 89 Member For: 15y 5m Gender: Male Posted 03/06/17 07:59 AM Share Posted 03/06/17 07:59 AM Just need some info installing a Walbro 460 into a FG F6 using the factory cradle having problems with fuel hose kinking when I compress the cradle. Im using 7.9mm rubber hose seems stiff when its cut short compared to the factory plastic flexible hose. What hose do I use? Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 3m 12d Gender: Male Location: Perth Posted 03/06/17 08:31 AM Share Posted 03/06/17 08:31 AM I use gates submersible hose, but Loop it so the hose is free to flex, otherwise raceworks now do replacement hard plastic convoluted hose similar to the factory hose Link to comment Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 10y 10m 23d Gender: Male Location: SW Sydney Posted 03/06/17 09:25 AM Share Posted 03/06/17 09:25 AM That the green stripe stuff Ralph? E85 rated, correct? Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 3m 12d Gender: Male Location: Perth Posted 03/06/17 09:35 AM Share Posted 03/06/17 09:35 AM (edited) No, green stripe isn't submersible. It's a specific hose designed for in tank use. It's rated for alcohol and petroleum submersion. http://www.gates.com/products/automotive/passenger-car-and-light-truck/fuel-system/submersible-fuel-line-hose Needs to be sae30r10 or higher. I don't have a piece with the part number handy unfortunately Edited 03/06/17 09:42 AM by Ralph Wiggum Link to comment Share on other sites More sharing options...
shaness8 Member 89 Member For: 15y 5m Gender: Male Posted 03/06/17 09:38 AM Author Share Posted 03/06/17 09:38 AM Tried looping the hose still Kincks noticed the pump snout is about 10-15mm higher than standard, don't really want to cut the snout down. might have to try the raceworks hose where do I buy that stuff thanks Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 3m 12d Gender: Male Location: Perth Posted 03/06/17 09:43 AM Share Posted 03/06/17 09:43 AM (edited) Is the pump seated properly? Edited 03/06/17 09:49 AM by Ralph Wiggum Link to comment Share on other sites More sharing options...
shaness8 Member 89 Member For: 15y 5m Gender: Male Posted 03/06/17 09:54 AM Author Share Posted 03/06/17 09:54 AM (edited) Yeah sort of goes in 1 way so think seated ok with the filter on top of the snout sits about 25mm from the top of the cradle Edited 03/06/17 09:57 AM by shaness8 Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 7m 4d Gender: Male Location: Adelaide Posted 03/06/17 01:14 PM Share Posted 03/06/17 01:14 PM I use new E85 rated corrugated hose looped each and every time I do a pump install regular hose as you've found out has a tendency to kink, even with the supplied stuff in the kit 1 Link to comment Share on other sites More sharing options...
shaness8 Member 89 Member For: 15y 5m Gender: Male Posted 03/06/17 02:01 PM Author Share Posted 03/06/17 02:01 PM That's the hose I need, where can I buy some of that. Thanks for the picture JET. Link to comment Share on other sites More sharing options...
Gabbo_32 Member 69 Member For: 10y 8m 14d Gender: Male Location: SE Melbourne, Victoria Posted 03/06/17 02:41 PM Share Posted 03/06/17 02:41 PM https://www.efihardware.com/products/2524/Submersible-Flex-Fuel-Hose-E85-Compatible-150mm-Long Link to comment Share on other sites More sharing options...
