300rwkw cost
Chels69
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 7m 18d
cat, injectors, fuel pump all tuned on E85 will get you to 300rwkw (probably around $2-3k spend) and you can get a high 11, low 12 depending on how much boost.
:Welcome2FordXR6t:
  • Site Developer
that's true, but it'll probably end up costing you more for a consistent 300rwkw with 98 as you need to think of intercooler/piping as the small turbo is out of it's efficiency range to make over 300rwkw consistently on 98.
  • New Member
  • Member For: 7y 11m 4d
I went and saw a reputable tuner and he said just with piping, injectors, xcal4, dyno tune with the dsg tune should net around ~300rwkw. This was for a FG MKII. I asked about changing the cat and he said it'll flow just fine for 300rwkw.
  • Site Developer
stock cat is the most restrictive part of the setup, especially on an FG mkII, so you generally need to replace it as you get above 280rwkw.
DSG tune? there's no dual clutch gearbox in a Falcon haha
  • Member For: 16y 3m 23d
Full exhaust, 60lbs injectors, intercooler and the 98 tune got me 325rwkw. I think it was around 3g but I had other stuff done too.
  • WOT?
  • Moderating Team
  • Member For: 11y 9m 3d
MkII just has a ring in the cat that can be knocked out - will be fine, no need for hi-flow cat
