My_XR6_Turbo Member 282 Member For: 20y 5m 7d Posted 16/05/17 09:48 AM Share Posted 16/05/17 09:48 AM What's involved in swapping to e85? Once upgraded and tuned can you use 98 if you can't get e85 for some reason? Has anyone had problems running e85? Link to comment Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,433 Member For: 15y 14d Gender: Male Location: Melbourne Posted 16/05/17 09:56 AM Share Posted 16/05/17 09:56 AM speak to your tuner is the best as we know nothing about your current set up but generally the fuel system may need beefing up fuel pump/injectors/surge tank/e85 safe hoses etc, drain tank and lines. re tune. if you cant get e85, run your tank as empty as your willing to go, fill up with 98, switch your tune if you have xcal. away you go. e85 has its pros and cons, been covered 100s times, im sure theres heaps of threads about it. its not for everyone that's for sure.! 1 Link to comment Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 10y 10m 27d Gender: Male Location: SW Sydney Posted 16/05/17 10:00 AM Share Posted 16/05/17 10:00 AM @My_XR6_Turbo read this thread thru Plenty of info......and some lols http://www.fordxr6turbo.com/forum/topic/77949-e85/ Link to comment Share on other sites More sharing options...
My_XR6_Turbo Member 282 Member For: 20y 5m 7d Posted 16/05/17 10:03 AM Author Share Posted 16/05/17 10:03 AM Thanks for the quick reply and great info. I've been reading and see that people are getting really good results running e85. ATM I have a 255l pump, 42psi injectors, cold and hot side 3" piping with large plazmaman cooler, flapper mod and 12psi actuator. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 3m 16d Gender: Male Location: Perth Posted 16/05/17 10:08 AM Share Posted 16/05/17 10:08 AM Your injectors and pump are miles to small for e85 1 Link to comment Share on other sites More sharing options...
Puffwagon Trust me bro... Gold Donating Members 16,044 Member For: 9y 11m 10d Gender: Male Location: South Australia Posted 16/05/17 10:18 AM Share Posted 16/05/17 10:18 AM 15 minutes ago, My_XR6_Turbo said: What's involved in swapping to e85? Bare minimum is a tune. 15 minutes ago, My_XR6_Turbo said: Once upgraded and tuned can you use 98 if you can't get e85 for some reason? Yes but you'll need to change the tune to suit the fuel. 16 minutes ago, My_XR6_Turbo said: Has anyone had problems running e85? Yes. Mainly blockages and deterioration. Tune issues are constantly present as the ford pcm is not suited to flex fuel tuning. Availability can be an issue. Link to comment Share on other sites More sharing options...
My_XR6_Turbo Member 282 Member For: 20y 5m 7d Posted 16/05/17 10:25 AM Author Share Posted 16/05/17 10:25 AM Ok this is starting to sound like hard work for a daily driver. I was hoping just a pump/injectors/tune and then see massive gains looking at the link above, fuel rail and reg needs upgrading. If staying with 98 and upgrading the plenum what gains can be seen? Link to comment Share on other sites More sharing options...
Puffwagon Trust me bro... Gold Donating Members 16,044 Member For: 9y 11m 10d Gender: Male Location: South Australia Posted 16/05/17 10:38 AM Share Posted 16/05/17 10:38 AM 6 minutes ago, My_XR6_Turbo said: pump/injectors/tune and then see massive gains That's the short of it. Your fuel filter might get blocked to start with but that's no biggie. No need for more than that for hectic gains. Of course if you want more then more needs to be done. Get to reading mate and see what works for you. Link to comment Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,433 Member For: 15y 14d Gender: Male Location: Melbourne Posted 16/05/17 12:15 PM Share Posted 16/05/17 12:15 PM e85 is not for you if you want quick n easy cheap way around it to just get some gains Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 2m 13d Gender: Male Location: Perth Posted 16/05/17 12:45 PM Share Posted 16/05/17 12:45 PM 2 hours ago, Ford Freak said: speak to your tuner is the best as we know nothing about your current set up but generally the fuel system may need beefing up fuel pump/injectors/surge tank/e85 safe hoses etc, drain tank and lines. re tune. if you cant get e85, run your tank as empty as your willing to go, fill up with 98, switch your tune if you have xcal. away you go. e85 has its pros and cons, been covered 100s times, im sure theres heaps of threads about it. its not for everyone that's for sure.! Can the HP tuners guys swap tunes between 98 and E85 like an xcal ?? Link to comment Share on other sites More sharing options...
