Puffwagon Gold Donating Members 16,348 Member For: 10y 4m 17d Gender: Not Telling Posted 31/01/18 10:46 AM Share Posted 31/01/18 10:46 AM The exhaust side is easy enough but I reckon the intake side would suck. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/93213-ba-wagon-turbo-conversion-using-ford-parts/page/5/#findComment-1651665 Share on other sites More sharing options...
NA_TURBO Member 532 Member For: 9y 8m 7d Gender: Male Location: Mildura Posted 31/01/18 10:51 AM Share Posted 31/01/18 10:51 AM On 31/01/2018 at 10:41 AM, Lunchietey said: Sounds a lot easier than changing the steel pipe around the back of the motor!Blue hoses to heater hoses 1 Link to comment https://www.fordxr6turbo.com/forum/topic/93213-ba-wagon-turbo-conversion-using-ford-parts/page/5/#findComment-1651666 Share on other sites More sharing options...
Lunchietey Member 84 Member For: 14y 10m 12d Gender: Male Location: WA Posted 31/01/18 01:18 PM Author Share Posted 31/01/18 01:18 PM Was tempted to do the exhaust side as the factory return line is right there at the bottom. If that can be done easily enough with the exhaust removed, I'll do that and tap the heater hose for the inlet. Awesome! Link to comment https://www.fordxr6turbo.com/forum/topic/93213-ba-wagon-turbo-conversion-using-ford-parts/page/5/#findComment-1651688 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 4m 17d Gender: Not Telling Posted 31/01/18 01:28 PM Share Posted 31/01/18 01:28 PM I did mine a few weeks ago but I had the manifold etc off already. I don't recall any dramas getting it on. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/93213-ba-wagon-turbo-conversion-using-ford-parts/page/5/#findComment-1651692 Share on other sites More sharing options...
Lunchietey Member 84 Member For: 14y 10m 12d Gender: Male Location: WA Posted 02/02/18 05:56 AM Author Share Posted 02/02/18 05:56 AM (edited) So looks like I should get 2 weeks in the second half of March to do the majority of the work. I decided to get a new wastegate as I am not actually sure of the condition of it, and not using an EBC means I am relying on a working gate. Going to order an IWG from turbosmart and can't decide on 5 or 7 psi. I will be using stock injectors with the 4 bar XR6T regulator and all other stock XR6T turbo parts including the exhaust (modded to fit the wagon). Will everything support the 7 psi spring or should I play it safe with the 5psi version? Edited 02/02/18 05:58 AM by Lunchietey Link to comment https://www.fordxr6turbo.com/forum/topic/93213-ba-wagon-turbo-conversion-using-ford-parts/page/5/#findComment-1651770 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,552 Member For: 17y 2m 5d Gender: Male Location: Melbourne Posted 02/02/18 06:22 AM Share Posted 02/02/18 06:22 AM You basically choose a wastegate strength rating by what you want your "minimum" boost delivery to be if you're shooting for reasonably low boost. With good tuning and reasonable mechanical condition of supporting parts, the wastegate should be able to hold roughly double it's rating at maximum, but it won't be a nice boost curve at it's maximum capacity. Link to comment https://www.fordxr6turbo.com/forum/topic/93213-ba-wagon-turbo-conversion-using-ford-parts/page/5/#findComment-1651771 Share on other sites More sharing options...
Lunchietey Member 84 Member For: 14y 10m 12d Gender: Male Location: WA Posted 02/02/18 06:31 AM Author Share Posted 02/02/18 06:31 AM (edited) Being an NA block, I believe 9-10psi is my realistic maximum anyway, just wondering if 7psi was doable with what I'll be doing. I'm 'assuming' it will be ok, just hoping to get someone who knows for sure! Edited 02/02/18 06:37 AM by Lunchietey Link to comment https://www.fordxr6turbo.com/forum/topic/93213-ba-wagon-turbo-conversion-using-ford-parts/page/5/#findComment-1651772 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,552 Member For: 17y 2m 5d Gender: Male Location: Melbourne Posted 02/02/18 07:04 AM Share Posted 02/02/18 07:04 AM 7psi will be fine, then. 1 1 Link to comment https://www.fordxr6turbo.com/forum/topic/93213-ba-wagon-turbo-conversion-using-ford-parts/page/5/#findComment-1651773 Share on other sites More sharing options...
Lunchietey Member 84 Member For: 14y 10m 12d Gender: Male Location: WA Posted 11/03/18 07:45 AM Author Share Posted 11/03/18 07:45 AM Made a small start before my shifts started. Immediately discovered no hole for intercooler pipe(bottom hose) and that even though there are holes that line up with the intercooler brackets, they do NOT allow the intercooler to fit. Chickened out and went 5 psi wastegate for now haha. Also found a split in one of the intercooler hoses(replacement located) and also realised I need to order the MAP adaptor loom(easier than replacing the plug) Also need to figure out how to replace the steel lines for the heater pipes as I've never done them before but sure it can't be TOO hard lol. Oh well got some time off starting Wednesday to figure it all out! Link to comment https://www.fordxr6turbo.com/forum/topic/93213-ba-wagon-turbo-conversion-using-ford-parts/page/5/#findComment-1653622 Share on other sites More sharing options...
Lunchietey Member 84 Member For: 14y 10m 12d Gender: Male Location: WA Posted 12/03/18 03:36 AM Author Share Posted 12/03/18 03:36 AM (edited) Ok so before my nightshifts, I have moved the trans cooler back(big aftermarket type) against the rad for full room for the cooler. Top pipe looks easy enough but the hot pipe looks like metal needs cutting on a wagon to get it to fit. Does an xr6t have a hole in the rail or something? On the wagon it looks like pretty solid metal or does the hose go under the rail? Anyone have a good pic of where the hot pipe goes at the front corner? Edited 12/03/18 03:38 AM by Lunchietey Link to comment https://www.fordxr6turbo.com/forum/topic/93213-ba-wagon-turbo-conversion-using-ford-parts/page/5/#findComment-1653651 Share on other sites More sharing options...
