courtjesterau New Member 19 Member For: 8y 4m 27d Posted 15/05/17 09:18 PM Share Posted 15/05/17 09:18 PM I have a FGMK 2 XR6 which is an ex police car, and I think I am having some issue with teh car electrically.I have an airbag light on and the DSC light on. The airbag I had scanned and found it was a front impact severity sensor. I swapped this out and the airbag light turned off. However, after about 2 weeks it came back on. I feel like it will be the same sensor as when I removed the faulty one it had already been changed once before(the one that was replaced had pain pen on it like it was from the wreckers)so this was not the first time it has had this issue. I plan to check the wiring and replace this again which will turn it off again.Also I have an issue with my DSC. The DSC light comes on the dash once I start the car. THE ABS light is Not on.The brake lights work and so does the cruise control even with the DSC fault. I had it scanned and they were unable to communicate with the DSC module in the car, which is why I think there may be a wiring issue.I have checked all fuses under the bonnet and on the driver side and all are fine and all connectors are plugged in firmly. The DSC fault appears immediately once you start the car.my question is where in the car is this module / ECU that controls the DSC system? Is it the Main ECU or elsewhere?I will be pulling the front bar and going over the wiring that this airbag sensor connects to I want to also look for any obvious faults with this ECU / wiring that controls the DSC system, so any help as to where I should be looking for this would be a help Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,117 Member For: 16y 8m 28d Gender: Male Location: Melbourne Posted 15/05/17 11:28 PM Share Posted 15/05/17 11:28 PM The hydraulic system itself looks like this (for the ABS/TCS/DSC system) -> The ABS controller in the engine bay (which looks like the pic below) gets electrical inputs from the ECU to control the above hydraulic system. (it's a self-contained system that can only be diagnosed if you have the right equipment) The system has a bunch of electrical sensors that could be causing the symptoms you're getting. Check on those, first. - yaw rate sensor - steering angle sensor - wheel speed sensors Link to comment Share on other sites More sharing options...
courtjesterau New Member 19 Member For: 8y 4m 27d Posted 16/05/17 10:00 AM Author Share Posted 16/05/17 10:00 AM I have checked all the wheel sensors and caould not see anything obvious and if that was the issue it should have come up in a scan thanks for the pic, so the DSC / ABS is the same / one module? now im more confused, as the ABS light is not on and ABS is working but they were unable to scan it. can the ABS work even though this ECU is faulty? I might buy a wreck and start swapping bits out Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,117 Member For: 16y 8m 28d Gender: Male Location: Melbourne Posted 16/05/17 10:02 AM Share Posted 16/05/17 10:02 AM Yes, the DSC/ABS/TCS is the same module. Don't worry about the ABS light. If you ahve a DSC light then troubleshoot the sensors I told you about. Link to comment Share on other sites More sharing options...
courtjesterau New Member 19 Member For: 8y 4m 27d Posted 16/05/17 10:34 AM Author Share Posted 16/05/17 10:34 AM (edited) they could not communicate with teh module to tell me which sensor it was (if it is) I have looked at the wheel sensors and could not see anything obvious, where approx is the yaw rate sensor located? Edited 16/05/17 10:36 AM by courtjesterau Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,117 Member For: 16y 8m 28d Gender: Male Location: Melbourne Posted 16/05/17 10:47 AM Share Posted 16/05/17 10:47 AM I've never physically seen one, but I'm pretty sure it's inside the same module in a sealed unit. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 3m 15d Gender: Male Location: Perth Posted 16/05/17 10:53 AM Share Posted 16/05/17 10:53 AM Yaw sensor is located on the steering column Link to comment Share on other sites More sharing options...
courtjesterau New Member 19 Member For: 8y 4m 27d Posted 16/05/17 10:55 AM Author Share Posted 16/05/17 10:55 AM 1 minute ago, Ralph Wiggum said: Yaw sensor is located on the steering column I thought that was the steering angle sensor? Where is the steering angle sensor then or is it the same unit on the colum? Link to comment Share on other sites More sharing options...
