ItsWarps New Member 8 Member For: 8y 22d Posted 05/05/17 12:30 AM Share Posted 05/05/17 12:30 AM Alright fellas, spent 4 bloody hours wiring up a new head unit in the falcon lastnight, wired up correctly everything was working perfectly, then once I put all the panels back on the new head unit won't play sound? Still has power and works and the icc works fine but for some reason no sound? Could it be a kink in the wires doing somewhere doing it? Link to comment https://www.fordxr6turbo.com/forum/topic/93174-help/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,510 Member For: 17y 1m 12d Gender: Male Location: Melbourne Posted 05/05/17 12:33 AM Share Posted 05/05/17 12:33 AM you probably shorted a connection which would have blown one of the fuses for the head unit. Link to comment https://www.fordxr6turbo.com/forum/topic/93174-help/#findComment-1638098 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 29d Gender: Male Location: Perth Posted 05/05/17 12:38 AM Share Posted 05/05/17 12:38 AM How did you wire the speakers? directly to the HU or through an Amp? Link to comment https://www.fordxr6turbo.com/forum/topic/93174-help/#findComment-1638099 Share on other sites More sharing options...
ItsWarps New Member 8 Member For: 8y 22d Posted 05/05/17 12:49 AM Author Share Posted 05/05/17 12:49 AM @Ralph Wiggum direct to the hu @k31th yeah gonna get a new fuse for the headunit and see how that goes Link to comment https://www.fordxr6turbo.com/forum/topic/93174-help/#findComment-1638101 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,510 Member For: 17y 1m 12d Gender: Male Location: Melbourne Posted 05/05/17 12:53 AM Share Posted 05/05/17 12:53 AM yeah, check the stock in-car fuse as well, as it's possible that that blew, too. Link to comment https://www.fordxr6turbo.com/forum/topic/93174-help/#findComment-1638103 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 29d Gender: Male Location: Perth Posted 05/05/17 12:55 AM Share Posted 05/05/17 12:55 AM If the headunit is powering up but not delivering sound why would you check fuses? Clearly it's getting power. More likely you've accidentally muted the unit or selected preouts instead of internal amp when fiddling around putting it back in. Link to comment https://www.fordxr6turbo.com/forum/topic/93174-help/#findComment-1638104 Share on other sites More sharing options...
ItsWarps New Member 8 Member For: 8y 22d Posted 05/05/17 01:21 AM Author Share Posted 05/05/17 01:21 AM @Ralph Wiggum yeah true, I'll muck around with the settings on the headunit a bit more whenI knock just incase I have Link to comment https://www.fordxr6turbo.com/forum/topic/93174-help/#findComment-1638105 Share on other sites More sharing options...
Uberxr New Member 9 Member For: 8y 5m 17d Posted 05/05/17 01:39 AM Share Posted 05/05/17 01:39 AM Honestly who thinks fuses when he clearly stated the ICC and HU both have power? Link to comment https://www.fordxr6turbo.com/forum/topic/93174-help/#findComment-1638106 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,510 Member For: 17y 1m 12d Gender: Male Location: Melbourne Posted 05/05/17 02:06 AM Share Posted 05/05/17 02:06 AM honestly you didn't even suggest what might be the problem? I've had a similar thing happen with a HU that had a separate fuse for the speaker outputs versus the power. Link to comment https://www.fordxr6turbo.com/forum/topic/93174-help/#findComment-1638107 Share on other sites More sharing options...
ItsWarps New Member 8 Member For: 8y 22d Posted 05/05/17 04:26 AM Author Share Posted 05/05/17 04:26 AM @k31th I just reset all the head unit settings just incase I've somehow muted the head unit but still no luck, which fuse is the HU fuse on the fuse panel? Can anyone supply a pic ? I'm a rookie Link to comment https://www.fordxr6turbo.com/forum/topic/93174-help/#findComment-1638112 Share on other sites More sharing options...
