  • New Member
  • Member For: 8y 2m 22d
Hey all, Having a boost issue with my BA (Cooler, 4 inch dump & exhaust, injectors, X4 with custom tune 297kw@14psi, currently running custom 10psi safe tune), 1st will boost to about 5psi the 0psi, 2nd will spool up then 0psi, currently nursing.
No fault codes appearing,  so far have checked/replaced,
-piping, joiners & BOV vacuum lines (replaced the sh*t turbo intake & throttle body joiners & vac lines with silicones and T-bolts)
-intake/exhaust & turbo manifold bolts (exhaust manifold bolts were loosish to my suprise)
-wastegate solenoid to actuator & turbo lines. (solenoid maintenance at the same time)
-wastegate for movement (not sticking)
I am leaning towards a failing actuator diaphragm or spring because when I checked that the wastegate was moving it seemed that the spring tension was quite soft (checked the tension on a spare diesel turbo) in comparison.
any input is greatly appreciated.
https://www.fordxr6turbo.com/forum/topic/93167-help-with-diagnosis/
  • Member For: 20y 8m 10d
Sounds like you have checked the basics up to now.
Have you considered removing the boost pressure sensor and cleaning it or at least having a look at it?
The part looks like this
http://www.ebay.com.au/itm/GENUINE-FORD-BA-BF-FG-MK2-FALCON-SX-SY-TERRITORY-TURBO-BOOST-PRESSURE-SENSOR/291215473643
On a standard BA xr6 turbo it will be located on the intake pipe near the battery. If this is faulty it could cause the problems your describing.
Should have a trouble code associated with this type of sensor failure, however with a tuned car who knows.
Sounds like a waste gate problem
Good luck mate
  • New Member
ok for some weird reason my car has fixed itself (not complaining),
I will still pull of the BPS for inspection and a clean this weekend,
Has this ever happened to anyone before?
  • 8 months later...
