Faulty Fuel Sender
crazyhorse
  • Member For: 16y 1m 15d
  • Gender: Female
Hi all
My 2008 FG turbo ute has a faulty fuel sender. Ford want to sting me $790 to replace it. Found the part on eBay for $120. :ermm: Anyone had any experience in replacing these and are they hard to do?
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 10m 18d
sounds like ford wanted to remove and then refit a whole tank :stirthepot:
For sedan: There a connection in the fuel module just underneath the rear passenger seat on the left-hand side to a float arm. If the float arm is the problem, then you will likely need to remove the tank to fix it. If the electrical sender bit connected to the float arm is the issue then it's just a matter of replacing that bit and refitting the fuel module.
For ute: you do have to remove the tank from the car to install it, so the price from Ford probably included quite a few hours of labour.
EDIT: didn't realise it was a ute...
Edited by k31th
  • Gender: Female
Yup sounds like it's a bit too much to do at home or test the patience of the husband:wild:... worth the $780 to not have to deal with that tantrum haha. Thanks guys, appreciate the quick responses!
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 8m 28d
I can have an FG ute tank out, pump swop ( inc sender ) and back in all in around 30min
FG is easy !!
Nope
Drop the whole tank down from below, never ever lifted a tub or cut a hole
up on the hoist and a few support brackets and out she comes ;)
The ute tank is held up by only Two big support straps that go all the way around the tank with 15mm bold heads fasteners
on the FG the fuel filler is shorter and fixed to the tank and the top connections are left in place but disconnected by the 90* lower push fittings
comes out like a glove
the B series is a touch longer process with needing to slide the diff back 150mm but that's only a tailshaft and 8 "U" bracket bolts on the leafs ;)
see
