My_XR6_Turbo Member 282 Member For: 20y 9m 2d Posted 20/04/17 02:04 AM Share Posted 20/04/17 02:04 AM Ok, I though I would write a a quick "how to" on replacing the stock oil feed line with an Earls filter kit. I did this while I was changing my oil so I had the oil filter removed which made it a lot easier. Start off by removing the sender cable from the sensor. Now use a long socket and remove the sender unit. This is what should be left on the car. Remove the washer and the old oil feed line and the washer behind the feed line. (unclip the old line from around the top of the engine will make it easier to move) Use another long socket and remove the adapter that goes to the block Put the adapter into the vice and inside the unit remove the clip. With the clip removed now pull the small filter out. The instructions I had said to clean it and put it back. I pulled mine out and left it out. When I put the banjo over the adapter I noticed the hole didn't really line up so I elongated the hole. Now I'm happy the oil will flow. Now remove the old oil line from the turbo and throw it in the bin. Screw the adapter into the turbo to receive the braided line. Install the adapter back into the engine. You will need to use some sealer on the threads. Screw the braided cable to the banjo. Put the washer then the banjo then the washer and the sensor back on and plug the cables back in. Run the braided lines to the filter and tighten everything up. Make sure you take note on which way the arrow is facing on the filter when you install it! I'm currently making a bracket from aluminum that screws to the from of the engine to hold the filter. 2 Link to comment https://www.fordxr6turbo.com/forum/topic/93135-how-to-install-an-earls-filter-kit/ Share on other sites More sharing options...
El Andrew Gold Donating Members 2,036 Member For: 10y 11d Gender: Male Location: Canberra ACT Posted 20/04/17 03:53 AM Share Posted 20/04/17 03:53 AM Nice write up. Does anyone wrap their filter in heat shielding? I ended up getting my mechanic to install my line at the same time the new turbo went in. He wrapped the filter but it looks crap. Link to comment https://www.fordxr6turbo.com/forum/topic/93135-how-to-install-an-earls-filter-kit/#findComment-1636926 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,332 Member For: 10y 3m 4d Gender: Male Location: South Australia Posted 20/04/17 04:24 AM Share Posted 20/04/17 04:24 AM On 20/04/2017 at 3:53 AM, El Andrew said: Does anyone wrap their filter in heat shielding? Expand Why would ya? The oil inside the line is going to be a lot hotter than the air under the bonnet and the stock line was never wrapped. Link to comment https://www.fordxr6turbo.com/forum/topic/93135-how-to-install-an-earls-filter-kit/#findComment-1636931 Share on other sites More sharing options...
El Andrew Gold Donating Members 2,036 Member For: 10y 11d Gender: Male Location: Canberra ACT Posted 20/04/17 04:33 AM Share Posted 20/04/17 04:33 AM Yeah that's what I figured. Reckon I'll rip it off next time I clean it. Link to comment https://www.fordxr6turbo.com/forum/topic/93135-how-to-install-an-earls-filter-kit/#findComment-1636932 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,332 Member For: 10y 3m 4d Gender: Male Location: South Australia Posted 20/04/17 04:50 AM Share Posted 20/04/17 04:50 AM You can see in the pic above that the only wrapped bit is just above the ex manifold. If the filter was right there then maybe consider wrapping it but otherwise, naaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh Link to comment https://www.fordxr6turbo.com/forum/topic/93135-how-to-install-an-earls-filter-kit/#findComment-1636938 Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,440 Member For: 15y 4m 8d Gender: Male Location: Melbourne Posted 20/04/17 10:06 AM Share Posted 20/04/17 10:06 AM oh wow how many people have installed these and this is the first time ive seen and or heard that the hole in the adaptor needs to be drilled out WTF? Link to comment https://www.fordxr6turbo.com/forum/topic/93135-how-to-install-an-earls-filter-kit/#findComment-1636976 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,467 Member For: 17y 24d Gender: Male Location: Melbourne Posted 20/04/17 10:07 AM Share Posted 20/04/17 10:07 AM it's a completely unnecessary step. he's just being overly cautious. Link to comment https://www.fordxr6turbo.com/forum/topic/93135-how-to-install-an-earls-filter-kit/#findComment-1636977 Share on other sites More sharing options...
My_XR6_Turbo Member 282 Member For: 20y 9m 2d Posted 20/04/17 10:18 AM Author Share Posted 20/04/17 10:18 AM If it's apart why not do it? Link to comment https://www.fordxr6turbo.com/forum/topic/93135-how-to-install-an-earls-filter-kit/#findComment-1636979 Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,440 Member For: 15y 4m 8d Gender: Male Location: Melbourne Posted 20/04/17 12:02 PM Share Posted 20/04/17 12:02 PM yer definitely I just dont understand why after all these years its never been brought up? Link to comment https://www.fordxr6turbo.com/forum/topic/93135-how-to-install-an-earls-filter-kit/#findComment-1636986 Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,440 Member For: 15y 4m 8d Gender: Male Location: Melbourne Posted 20/04/17 12:20 PM Share Posted 20/04/17 12:20 PM when you Screwed the adaptor into the turbo to receive the braided line does it need any sealent? what do you use Link to comment https://www.fordxr6turbo.com/forum/topic/93135-how-to-install-an-earls-filter-kit/#findComment-1636991 Share on other sites More sharing options...
