Nitro_420 New Member 4 Member For: 7y 9m 18d Posted 16/04/17 12:23 PM Share Posted 16/04/17 12:23 PM hey all, recently had my zf box built with new convertor, exedy stage 1 friction kit, bronze bush kit, oversize pressure regulator, new steels and a new clutch e pressure plate etc. I've noticed my speedo is now reading out, at 40kmh it reads 50 and getting up to 100 it reads 80 on the speedo. the zf has previously had a tune and im thinking will it need a retune on the box to sort my speedo out or have I got other problems? I've already tried returning the tune to stock on xcal 3 and reloading the tune in hope it might fix the problem but no good. any help appreciated thanks Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,089 Member For: 10y 5d Gender: Male Location: South Australia Posted 16/04/17 12:27 PM Share Posted 16/04/17 12:27 PM You haven't changed wheels by any chance? Just take it back to the tuner and politely ask them to fix the job you paid for. Link to comment Share on other sites More sharing options...
Nitro_420 New Member 4 Member For: 7y 9m 18d Posted 16/04/17 12:31 PM Author Share Posted 16/04/17 12:31 PM na haven't changed the wheels. guess ill have to give them a call tuesday then, thanks Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,089 Member For: 10y 5d Gender: Male Location: South Australia Posted 16/04/17 12:49 PM Share Posted 16/04/17 12:49 PM All good. It should just be tune related and can be fixed fairly quickly. It might help to measure the circumference of your rear tyre so the tuner has that info to double check stuff. Link to comment Share on other sites More sharing options...
Nitro_420 New Member 4 Member For: 7y 9m 18d Posted 16/04/17 01:26 PM Author Share Posted 16/04/17 01:26 PM Hoping it's just tune related and I haven't broken something else haha. Just odd that the speedo doesn't read the same speed consistently wrong, it gets more inaccurate the faster I go Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,089 Member For: 10y 5d Gender: Male Location: South Australia Posted 16/04/17 01:40 PM Share Posted 16/04/17 01:40 PM 1 hour ago, Nitro_420 said: I've noticed my speedo is now reading out, at 40kmh it reads 50 and getting up to 100 it reads 80 on the speedo. That looks like 20% to me. Just reading your initial post again it looks like you had a stock trans with a tune and then got it rebuilt without a retune? I think I may have incorrectly assumed you had it tuned after the rebuild. If this is the case then you should get it tuned for the hard parts as well as checking the speedo issue. 1 Link to comment Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,434 Member For: 15y 1m 9d Gender: Male Location: Melbourne Posted 16/04/17 11:28 PM Share Posted 16/04/17 11:28 PM your tuner can re calibrate the speedo problem yet I dont see how building the box does that but im happy to be told otherwise. first ive heard of that happening. weird. if you had your box built generally your tuner should re tune the shifts anyways to take advantage of everything. whos the tuner/ 1 Link to comment Share on other sites More sharing options...
4321 Bronze Donating Members 257 Member For: 10y 10m 8d Posted 17/04/17 12:05 AM Share Posted 17/04/17 12:05 AM This is odd, the speed signal is picked up from the wheels through the abs? Link to comment Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,434 Member For: 15y 1m 9d Gender: Male Location: Melbourne Posted 17/04/17 12:52 AM Share Posted 17/04/17 12:52 AM yep that's why when changing to bigger wheels it throws out the speedo. usually around 5 kays or so. possibly faulty sensor? but tune can fix it Link to comment Share on other sites More sharing options...
Nitro_420 New Member 4 Member For: 7y 9m 18d Posted 17/04/17 01:30 AM Author Share Posted 17/04/17 01:30 AM Yes originally had the box tuned and then when I had the box put back in I don't believe it was re tuned as I took it to a transmission specialist which is probably where I went wrong. Link to comment Share on other sites More sharing options...
