Jhosk26 New Member 4 Member For: 8y 18d Posted 15/04/17 07:44 AM Share Posted 15/04/17 07:44 AM Hey guys, so I drive a 2002 ba falcon and just yesterday it broke down during my 8 hour roadtrip. I was driving along goind around 110 km/h when suddenly what seemed to be the transmission, started jerking for a few seconds. Immediately after, the revs shot up to 3500, I'm assuming it went into 'limp' mode. I then started hearing strange noises such as a loud grinding noise coming from under the car, I immediately pulled over and could smell some sort of fluid, but there are no leaks. Now whenever I select Drive or Reverse I hear this grind noise. I assume this is very bad, has anyone else had a similar problem.. Any help would be much appreciated. Link to comment https://www.fordxr6turbo.com/forum/topic/93122-ba-falcon-transmission-problem/ Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 12y 4m 4d Gender: Not Telling Posted 15/04/17 10:47 AM Share Posted 15/04/17 10:47 AM checked the tailshaft and diff? Link to comment https://www.fordxr6turbo.com/forum/topic/93122-ba-falcon-transmission-problem/#findComment-1636614 Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,440 Member For: 15y 4m 7d Gender: Male Location: Melbourne Posted 15/04/17 11:25 AM Share Posted 15/04/17 11:25 AM whens the last time the auto was serviced? Link to comment https://www.fordxr6turbo.com/forum/topic/93122-ba-falcon-transmission-problem/#findComment-1636626 Share on other sites More sharing options...
Jhosk26 New Member 4 Member For: 8y 18d Posted 16/04/17 02:59 AM Author Share Posted 16/04/17 02:59 AM The driveline appears to be fine, not sure when the auto was last serviced.. Just checked the oil level, it's good Link to comment https://www.fordxr6turbo.com/forum/topic/93122-ba-falcon-transmission-problem/#findComment-1636657 Share on other sites More sharing options...
Jhosk26 New Member 4 Member For: 8y 18d Posted 20/04/17 08:02 AM Author Share Posted 20/04/17 08:02 AM For anyone interested, it turns out the clutch in the auto had burnt out. I paid a mechanic to fit another transmission, but it still jerks when coasting and slips gears.. Apparently very common. Definitely won't be buying another BA Link to comment https://www.fordxr6turbo.com/forum/topic/93122-ba-falcon-transmission-problem/#findComment-1636962 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 9d Gender: Male Location: Perth Posted 20/04/17 08:16 AM Share Posted 20/04/17 08:16 AM Smells If it's still slipping either the new trans is dicked or there is another issue. Get the fluid level checked ASAP before you hurt the replacement. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/93122-ba-falcon-transmission-problem/#findComment-1636963 Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 12y 4m 4d Gender: Not Telling Posted 20/04/17 08:29 AM Share Posted 20/04/17 08:29 AM needs a 6 speed manual transmission. and sometimes ya buy a lemon Link to comment https://www.fordxr6turbo.com/forum/topic/93122-ba-falcon-transmission-problem/#findComment-1636964 Share on other sites More sharing options...
Jhosk26 New Member 4 Member For: 8y 18d Posted 23/04/17 03:03 AM Author Share Posted 23/04/17 03:03 AM Oh a 6 spd manual would be lovely, but I've heard its a big pain in the ass to do On 20 April 2017 at 6:16 PM, Ralph Wiggum said: Smells If it's still slipping either the new trans is dicked or there is another issue. Get the fluid level checked ASAP before you hurt the replacement. Will do, cheers. Link to comment https://www.fordxr6turbo.com/forum/topic/93122-ba-falcon-transmission-problem/#findComment-1637174 Share on other sites More sharing options...
