waynocrano Bronze Donating Members 3 Member For: 8y 6m 2d Posted 05/04/17 06:32 AM Share Posted 05/04/17 06:32 AM (edited) hi fullas I'm running 4 spot brembos and want to up grade to 6 spot on my bf I see on line plenty of fg conversions, does the bf need different mounting brackets to fg as the caliper on bf is front mounted and fg is rear mount? Is there traps for young players to watch for? any help or advice will be much appreciated Waynocrano Edited 05/04/17 06:41 AM by waynocrano Link to comment https://www.fordxr6turbo.com/forum/topic/93093-brake-up-grade-to-6-piston-brembo-bf/ Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 30d Gender: Male Location: Perth Posted 05/04/17 07:01 AM Share Posted 05/04/17 07:01 AM You can install FG Brembo's with FG Brackets on a B series but you'll need to swap the bleed screws and cross over pipes as the caliper sit on the opposite side of the disc on a FG so if installed directly onto a B series the cross over pipe is on top and bleed screw is on the bottom. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/93093-brake-up-grade-to-6-piston-brembo-bf/#findComment-1635922 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 6m 28d Gender: Male Location: Probably above atmospheric pressure Posted 05/04/17 12:35 PM Share Posted 05/04/17 12:35 PM Get them custom painted before you put them on 1 Link to comment https://www.fordxr6turbo.com/forum/topic/93093-brake-up-grade-to-6-piston-brembo-bf/#findComment-1635931 Share on other sites More sharing options...
MBAF Bronze Donating Members 2,156 Member For: 8y 10m 7d Posted 06/04/17 12:06 AM Share Posted 06/04/17 12:06 AM In bright kermit green 2 Link to comment https://www.fordxr6turbo.com/forum/topic/93093-brake-up-grade-to-6-piston-brembo-bf/#findComment-1635946 Share on other sites More sharing options...
waynocrano Bronze Donating Members 3 Member For: 8y 6m 2d Posted 27/04/17 10:16 AM Author Share Posted 27/04/17 10:16 AM awesome thank you ralph good to hear huge exspense I want to get it right. have you done the conversion. if so can you give me an idea of cost cutting avenues if there are any? Im heading down the kwinana strip perth atm. pulled over the side of road to reply I'm abit nervous about coming against some of these big bore supercharged HSVs, and I'm sure they'll be barra hunting.......looking forward to it...............whip ass wednesday...............in Perth...........I'll keep yas posted...gotta go waynocrano ??? Link to comment https://www.fordxr6turbo.com/forum/topic/93093-brake-up-grade-to-6-piston-brembo-bf/#findComment-1637571 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 6m 28d Gender: Male Location: Probably above atmospheric pressure Posted 27/04/17 01:35 PM Share Posted 27/04/17 01:35 PM Hope you mean next week, as it's Thursday today Link to comment https://www.fordxr6turbo.com/forum/topic/93093-brake-up-grade-to-6-piston-brembo-bf/#findComment-1637584 Share on other sites More sharing options...
HI PSI Member 1,589 Member For: 19y 28d Gender: Male Location: Central Queensland Posted 28/04/17 05:44 AM Share Posted 28/04/17 05:44 AM On 05/04/2017 at 7:01 AM, Ralph Wiggum said: You can install FG Brembo's with FG Brackets on a B series but you'll need to swap the bleed screws and cross over pipes as the caliper sit on the opposite side of the disc on a FG so if installed directly onto a B series the cross over pipe is on top and bleed screw is on the bottom. Expand Hi Luke, I'll be installing my Brembo's soon. Could you please tell me which way the small piston is supposed to face. Is it the lead piston for forward travel? Or do it have it arse about face? Link to comment https://www.fordxr6turbo.com/forum/topic/93093-brake-up-grade-to-6-piston-brembo-bf/#findComment-1637625 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 30d Gender: Male Location: Perth Posted 28/04/17 06:56 AM Share Posted 28/04/17 06:56 AM (edited) Yesir. Small piston on the rotor entry and big on the exit. Ensure the pads lead into the roto from the entry side. More progressive action and less chance of chatter. Keen for pics of 385's and associated bits. (make two set of spacers kthnxby) Edited 28/04/17 06:56 AM by Ralph Wiggum 1 Link to comment https://www.fordxr6turbo.com/forum/topic/93093-brake-up-grade-to-6-piston-brembo-bf/#findComment-1637633 Share on other sites More sharing options...
