  • ...JD TUNING ADELAIDE...
  • Member For: 16y 10m 29d
What do you mean as I don't reference either as I use a wideband for true lambda calculations then after the tuning is done the factory o2 sensors are only there to maintain the target lambda set by the tune ( +/- 0.02 lambda swing )
what exactly do you want to know ?
  • Member For: 13y 21d
@JETURBO
Just curious as my 2nd o2 sensor has never been connected. I realise now my dislexia (derr) took over when I initially wrote the post. I meant "does the ecu only use first o2 sensor for reference after flash?"
It's common for tune shops to turn off the 2nd o2 sensor especially when a big cat has been installed ;)
yes nathan it's a good idea
That explains that then. To me it seems useless anyway - why have another sensor downstream. Ive logged it and its exactly the same reading, just slightly delayed.
Also, @JETURBO do you know of anyone that can supply higher flowing versions of the standard 4bar bosch fuel regs?
Tia
  • Moar Powar Babeh
  • Member For: 19y 7m 6d
Post car O2 sensor measures cat efficiency. It has no bearing on closed the fuelling.
