EvilDaifu Cruise Whore Moderating Team 5,130 Member For: 19y 9m 8d Gender: Male Location: Melbourne Posted 24/03/17 12:18 AM Author Share Posted 24/03/17 12:18 AM Yep - as soon as the air fliter pod dries out and I've re-oiled it I'll 1. Run the engine and listen for any hissing sounds from possible leaking exhaust manifold. 2. Plug in the XCAL3 and check for DTC codes (as discussed with Rab) 3. Pull the battery and leave unconnected for 10 mins (thanks mazda74) 4. Flash back in my custom edit tune. 5. When I'm on the road to Radelaide - set cruise on 100km/h and check the instanenous fuel consumption read out. Not discounting issue with O2 sensor either - am guessing its a common issue though I've never encountered it before. Link to comment https://www.fordxr6turbo.com/forum/topic/93060-was-doing-average-15l-100km-but-now-doing-21l-100km/page/3/#findComment-1635104 Share on other sites More sharing options...
EvilDaifu Cruise Whore Moderating Team 5,130 Member For: 19y 9m 8d Gender: Male Location: Melbourne Posted 24/03/17 04:13 AM Author Share Posted 24/03/17 04:13 AM Just put SS Growler back together. By the way I went around the Turbo Intercooler head and some of the cir clamps were loose - especially the one connected to the pipe from the SS Growler so I hand tightened those. That's the right thing to do - right? We're not meant to leave them loose by 1/8 turn for expansion or something are we? Listened in engine bay and heard no hissing on exhaust side nor smelt any exhaust fumes. When I check for DTC codes with the XCAL3 I get a P1000 error. P1000 FORD - On Board Diagnostic System Readiness Test Not CompleteRead more: https://www.engine-codes.com/p1000_ford.html Is this the code that's always there if you have a custom edit? Rab mentioned something like that. Anyways gonna reset ECU next by disconnecting battery for 10 mins. Then plan to flash back in my custom edit. Link to comment https://www.fordxr6turbo.com/forum/topic/93060-was-doing-average-15l-100km-but-now-doing-21l-100km/page/3/#findComment-1635121 Share on other sites More sharing options...
Box stock T. Member 1,384 Member For: 10y 1m 6d Posted 24/03/17 04:26 AM Share Posted 24/03/17 04:26 AM (edited) I will show ya a pic of the O2 sensor when I see ya on Saturday mate. Then you'll know exactly what ya have to replace. I did one not long ago and still have the ebay pic and link on my phone. Edited 24/03/17 04:32 AM by Box stock T. Because I can 1 Link to comment https://www.fordxr6turbo.com/forum/topic/93060-was-doing-average-15l-100km-but-now-doing-21l-100km/page/3/#findComment-1635125 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 5m 19d Gender: Male Location: Probably above atmospheric pressure Posted 24/03/17 04:42 AM Share Posted 24/03/17 04:42 AM Just to add my BF had two O2 sensors not one (thought they always had two in B series onwards?), but as mentioned the second one (post cat) is disabled in tune and now just has a bung in there. It was rubbing against the ZF pan to housing flange due to position in aftermarket exhaust and no point leaving it in anyway! Link to comment https://www.fordxr6turbo.com/forum/topic/93060-was-doing-average-15l-100km-but-now-doing-21l-100km/page/3/#findComment-1635128 Share on other sites More sharing options...
El Andrew Gold Donating Members 2,036 Member For: 10y 21d Gender: Male Location: Canberra ACT Posted 24/03/17 05:09 AM Share Posted 24/03/17 05:09 AM That must mean the second one is only about cat effectiveness and not about monitoring AFRs. So if o2 sensor is the cause here, its only the pre-cat one that is in play. Link to comment https://www.fordxr6turbo.com/forum/topic/93060-was-doing-average-15l-100km-but-now-doing-21l-100km/page/3/#findComment-1635129 Share on other sites More sharing options...
El Andrew Gold Donating Members 2,036 Member For: 10y 21d Gender: Male Location: Canberra ACT Posted 24/03/17 05:33 AM Share Posted 24/03/17 05:33 AM That must mean the second one is only about cat effectiveness and not about monitoring AFRs. So if o2 sensor is the cause here, its only the pre-cat one that is in play. Link to comment https://www.fordxr6turbo.com/forum/topic/93060-was-doing-average-15l-100km-but-now-doing-21l-100km/page/3/#findComment-1635131 Share on other sites More sharing options...
EvilDaifu Cruise Whore Moderating Team 5,130 Member For: 19y 9m 8d Gender: Male Location: Melbourne Posted 24/03/17 06:28 AM Author Share Posted 24/03/17 06:28 AM Okay did everything up to putting the custom tune back in and now the average is 33.4l/100km - farrk me But only driven it around the block. I'm just happy it starts up okay ... So I'll be heading out soon to join Rab and k31th and will find out what the instantaneous shows when I'm crusing at 100km/h Link to comment https://www.fordxr6turbo.com/forum/topic/93060-was-doing-average-15l-100km-but-now-doing-21l-100km/page/3/#findComment-1635133 Share on other sites More sharing options...
El Andrew Gold Donating Members 2,036 Member For: 10y 21d Gender: Male Location: Canberra ACT Posted 24/03/17 06:59 AM Share Posted 24/03/17 06:59 AM Swapping the front sensor isn't a huge job - but need the heat shroud off. Maybe see if someone will swap sensors with you tomorrow morning for a back to back comparison? 1 Link to comment https://www.fordxr6turbo.com/forum/topic/93060-was-doing-average-15l-100km-but-now-doing-21l-100km/page/3/#findComment-1635138 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 5m 19d Gender: Male Location: Probably above atmospheric pressure Posted 24/03/17 10:07 AM Share Posted 24/03/17 10:07 AM Good idea, but do it at the end of the initial meet or bring your heat proof gloves hahaha Link to comment https://www.fordxr6turbo.com/forum/topic/93060-was-doing-average-15l-100km-but-now-doing-21l-100km/page/3/#findComment-1635151 Share on other sites More sharing options...
EvilDaifu Cruise Whore Moderating Team 5,130 Member For: 19y 9m 8d Gender: Male Location: Melbourne Posted 24/03/17 12:35 PM Author Share Posted 24/03/17 12:35 PM In Horsham fueling up. Averaged 8.7l / 100km so far 3 Link to comment https://www.fordxr6turbo.com/forum/topic/93060-was-doing-average-15l-100km-but-now-doing-21l-100km/page/3/#findComment-1635162 Share on other sites More sharing options...
