Pictures of Dual Zone heater hoses
HI PSI
  • Member For: 18y 7m 8d
Could some kind soul please post up some pictures of the their BA/BF dual zone heater hoses, where they connect to the solid lines and go through the firewall. As I am having a problem with the passengers side air conditioning being warm,  I need to confirm that I have them connected correctly. The temperature will get hotter when I change it's setting, so I think that it is not the mixer shaft. The only other thing it could be, is that the water is feeding backwards through the turbo, and feeding back to where it feeds from the heater hose...  Here is a pic of the current setup..
Any assistance you could give would be greatly appreciated.
  • Moar Powar Babeh
  • Member For: 19y 3m 9d
Pressure side (from the thermostat housing) should go to the bottom fitting on the core, suction hose to the top so the core remains full.
It does sound like a mixer issue though.
Edited by Ralph Wiggum
  • To Loud
  • Member For: 13y 1m 2d
Went out and took these for ya.
Not sure if that helps. Keep in mind that I have an FG
Edited by masda74
  • 3 years later...
  • New Member
  • Member For: 4y 11m 27d
Hi guys im just wanting to ask a question about  the diagram that was put up for the heater bypass I just purchased the replacement metal pipe from ford and wanting to know which pipes go to where from the factory oil cooler on the transmission the car is a 2006 BF series 11 XR6 hope some one has changed one before and if so how hard is it ? thanks Shane.
