arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 7m 23d Gender: Male Location: Perth Posted 13/04/17 02:10 PM Share Posted 13/04/17 02:10 PM Then you fit something that does both. QFM Z-8000 a bit noisy , but a great pad hot or cold, I have used nothing better. Link to comment https://www.fordxr6turbo.com/forum/topic/93048-brembo-brake-pad-reviews/page/2/#findComment-1636503 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 6m 25d Gender: Male Location: Probably above atmospheric pressure Posted 14/04/17 02:18 AM Share Posted 14/04/17 02:18 AM Brembo pad swaps are fast enough anyway it would only get annoying if you had to do it every weekend. Probably only take less than 5 minutes a side if you are organised. Failing that, as Arron said get a pad that does both! The HC800s were fine for daily driving just very dusty and harder on the rotors long term, and a bit of a squeak from them at low speeds. Link to comment https://www.fordxr6turbo.com/forum/topic/93048-brembo-brake-pad-reviews/page/2/#findComment-1636522 Share on other sites More sharing options...
HI PSI Member 1,589 Member For: 19y 25d Gender: Male Location: Central Queensland Posted 30/04/17 11:55 AM Author Share Posted 30/04/17 11:55 AM On 13/04/2017 at 2:10 PM, arronm said: Then you fit something that does both. QFM Z-8000 a bit noisy , but a great pad hot or cold, I have used nothing better. Expand Where can I source these? Link to comment https://www.fordxr6turbo.com/forum/topic/93048-brembo-brake-pad-reviews/page/2/#findComment-1637836 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 7m 23d Gender: Male Location: Perth Posted 30/04/17 12:17 PM Share Posted 30/04/17 12:17 PM Buy direct from QFM http://qfm.com.au/ Link to comment https://www.fordxr6turbo.com/forum/topic/93048-brembo-brake-pad-reviews/page/2/#findComment-1637837 Share on other sites More sharing options...
HI PSI Member 1,589 Member For: 19y 25d Gender: Male Location: Central Queensland Posted 30/04/17 01:40 PM Author Share Posted 30/04/17 01:40 PM Thanks mate. I feel a bit silly, I google it after I posted and quickly found the site. Apologies for wasting your time. Do you run these on both front and rear? I only ask, as I have noticed that some use a lower temp pad on the rear. Link to comment https://www.fordxr6turbo.com/forum/topic/93048-brembo-brake-pad-reviews/page/2/#findComment-1637839 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 7m 23d Gender: Male Location: Perth Posted 30/04/17 02:14 PM Share Posted 30/04/17 02:14 PM Just front. Link to comment https://www.fordxr6turbo.com/forum/topic/93048-brembo-brake-pad-reviews/page/2/#findComment-1637841 Share on other sites More sharing options...
HI PSI Member 1,589 Member For: 19y 25d Gender: Male Location: Central Queensland Posted 30/04/17 09:55 PM Author Share Posted 30/04/17 09:55 PM What do you run in the rear? Link to comment https://www.fordxr6turbo.com/forum/topic/93048-brembo-brake-pad-reviews/page/2/#findComment-1637843 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 7m 23d Gender: Male Location: Perth Posted 01/05/17 02:26 PM Share Posted 01/05/17 02:26 PM (edited) HP-X I have 6 + 4 brembo. Edited 01/05/17 02:26 PM by arronm Link to comment https://www.fordxr6turbo.com/forum/topic/93048-brembo-brake-pad-reviews/page/2/#findComment-1637893 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 27d Gender: Male Location: Perth Posted 01/05/17 11:41 PM Share Posted 01/05/17 11:41 PM Brett, I run PMU HC800+ fronts and NS400 rears in the F6. Have been dailying it the last few days and the initial bite from the HC800's is excellent. You can't tell they are a street/track pad until you lean on the pedal and it throws you through the windscreen. Link to comment https://www.fordxr6turbo.com/forum/topic/93048-brembo-brake-pad-reviews/page/2/#findComment-1637898 Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 13y 1m 15d Gender: Male Location: Central Coast Posted 02/05/17 12:24 AM Share Posted 02/05/17 12:24 AM Forza FP3, Both F+R Brembo 4 + 1 Very dusty, Abit Spongy while cold, Actually got some heat into them while in canberra on some back roads. They performed excellent when warmed up, great bite and stayed that way. As a daily wouldn't do it again though Link to comment https://www.fordxr6turbo.com/forum/topic/93048-brembo-brake-pad-reviews/page/2/#findComment-1637905 Share on other sites More sharing options...
