  • Member For: 12y 1m 4d
I'm in the same boat- except I had to do the cat replacement when my factory unit literally broke off- now learning to exercise a light right foot and it's harder than I thought it would be!
Also got the engine warning lamp as Puffwagon said.
Just waiting in line now for the tooooon to happen
  • New Member
  • Member For: 8y 1m 17d
Hi Breezy..thought I may have been in luck as exhaust manifold bolts were loose as puffwagon suggested but still down on power...
I'm dyslexic and cannot turn off simple functions in tapatalk
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 22d
  On 16/03/2017 at 3:03 AM, JETURBO said:
Soon @brenny soon :)
Expand
you tagged the wrong person, ya spanner! xD
  • Site Developer
it's still within the edit window - press the button and fix it yourself, ya lazy farker!
He was close LOL and I'm SO looking forward to it! Even though we're only going mild, it'll still be fun :beerchug:
@jollyjim81 yeah I thought mine might be too till it fell onto the ground - scraping my driveway everyday for 4 years I think just over stressed the flange crease and it cracked thru completely.
  • 7 months later...
  • New Member
  • Member For: 7y 6m 3d
How can a high flow cat install really endanger the engine? The turbo has boost control to avoid overboosting. How does it differ from putting a muffler delete pipe in which allows less exhaust restriction .
  • Site Developer
The factory "boost control" can only do so much. Overboost is possible with more flow than the other stock mechanical components can maintain. The stock GT3582R turbo (and the stock FG XR6T turbocharger, although not quite as capable) is far more capable than the other supporting stock parts.
The high flow cat increases flow of air away from the turbo much much faster than stock, whereas removing only a muffler just makes the car a little louder, but hardly increases air flow in comparison.
  • Puff
  • Member For: 10y 3m 2d
The factory boost control is designed to work with factory parts and will catch the rising boost curve in time so it doesn't overboost.
When you derestrict it with intake and exhaust mods the boost will rise quicker and earlier which the boost maps aren't tuned for.
It'll trigger 'overboost' which isn't the end of the world but obviously should be avoided.
You could swap various parts and just drive around it eg: give it half or 3/4 throttle without doing any damage but the proper thing to do is get it tuned.
