OZYWALKER XR50T Gold Donating Members 2,795 Member For: 11y 9m 15d Gender: Male Location: Western Sydney Posted 15/03/17 12:53 AM Share Posted 15/03/17 12:53 AM There's already been someone on here with a proflow surge that leaked out the welds. Link to comment Share on other sites More sharing options...
Ale Member 249 Member For: 13y 5m 22d Posted 15/03/17 01:00 AM Share Posted 15/03/17 01:00 AM no doubt there is, kinda expected isn't it? That's my point Link to comment Share on other sites More sharing options...
el-dub801 Member 44 Member For: 12y 10m 8d Gender: Male Location: Wollongong Posted 15/03/17 01:14 AM Author Share Posted 15/03/17 01:14 AM Ive run this tank/fuel system combo for a couple years before this happened. Its strange for it to crack now. Been pretty happy with all my Process West parts to be honest. Link to comment Share on other sites More sharing options...
el-dub801 Member 44 Member For: 12y 10m 8d Gender: Male Location: Wollongong Posted 26/03/17 03:13 AM Author Share Posted 26/03/17 03:13 AM So, it happened again... Racking my brain as to what could be causing it. The obvious says that there's too much pressure inside the tank - but why?? This time I noted several occurrences prior to it cracking: 1. After several starts (when the surge tank was out and running on its oem fuel system) it ran very rich, black smoke and stalling. Cleared once engine was off/on cycled at least 4 times. 2. Once the surge tank was refitted, engine started and ran. Turned off after 5 seconds to check under car for fuel leaks etc After second start, Bosch pump sounded like it was under immense pressure like it was pumping to nowhere - then CRACK and SPLASH. That was at 6pm, so I left it. I have a feeling I have one of two problems - a dodgy fuel regulator (car is 11 years old and has been modified since 2011 AND sat for 4 years) or there's a blockage in the return line to the tank. All sensors have been logged in regards to the running rich and nothing looked out of place. I'll check the return to eliminate that as its probably the easiest to rule out. As for the fuel reg, I'll replace it anyway as its not a pricey item. In regards to the regulator, I've read of blueprinted versions of the 4 bar Bosch regulators being on the market - is this true? and if so, where do I get one?? Thanks In Advance... Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 24d Gender: Male Location: Perth Posted 26/03/17 05:41 AM Share Posted 26/03/17 05:41 AM Pics? Link to comment Share on other sites More sharing options...
el-dub801 Member 44 Member For: 12y 10m 8d Gender: Male Location: Wollongong Posted 26/03/17 05:45 AM Author Share Posted 26/03/17 05:45 AM @ralph wiggum Not this time, but I did get a pic from last time. I'll upload it below. Although the new weld held up, it cracked on the opposite side. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 3m 20d Gender: Male Location: Perth Posted 26/03/17 05:49 AM Share Posted 26/03/17 05:49 AM (edited) It's now pretty obvious you are over pressurizing the surge. It is splitting from the inside where both parent metals join. Edited 26/03/17 05:56 AM by arronm Link to comment Share on other sites More sharing options...
el-dub801 Member 44 Member For: 12y 10m 8d Gender: Male Location: Wollongong Posted 26/03/17 06:10 AM Author Share Posted 26/03/17 06:10 AM @arronm I would definately think so too. It wouldn't have been designed as a pressure vessel either, so I could have the welds re-done all the way around but I would still have that high pressure situation. Heres my theory - the pump is flowing max pressure through the rail, back through the return line and back into the surge tank as well as the in-tank pump and maybe the return cant cope (or is blocked) Max pressure from both pumps would have to be in excess of 120ish psi (??) This would also be reason for intermitantly running rich - high ass fuel pressure -> rich mixtures at idle. Blocked return - highly unlikely but couldnt quite write that off unless I actually check it. Thoughts??? Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 3m 20d Gender: Male Location: Perth Posted 26/03/17 06:26 AM Share Posted 26/03/17 06:26 AM Mate you need to go through each connection to make sure each is correct and in the correct location check pressures and return fuel lines. It's trial and elimination. Once sorted just weld up the tank again. Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 8m 16d Gender: Male Location: Adelaide Posted 26/03/17 10:34 AM Share Posted 26/03/17 10:34 AM Sounds like a blockage in the return to tank line/swirl pot Link to comment Share on other sites More sharing options...
