Surge tank pumps and pump pressure
el-dub801
  • Member For: 12y 9m 17d
Guys (and girls?)
I had an odd occurance happen to me over the weekend with regards to my fuel system... I recently (finally) got my car going again after replacing a set of keys (thanks Ralph Wiggum) and with that came time to start the car after some time being unused. I replaced my in tank pump with a walbro 255 and the bosch 044 that's attached to a PW surge tank as the fuel had gone sh*tty and didnt want to risk it. I also wired up a relay to the 044 as it hadnt been installed when I had the surge tank installed initially. Typical relay wiring configuration as per recommendations.
I cranked the car without the 044 hooked up, then plugged in the fuse for the 044 relay and continued to crank until I heard the pump stop and fuel was primed. This is when I experienced the problem - I heard a loud "POP" and a splashing sound under the car, had a look and found fuel splashing out everywhere!
Climbed under and checked all lines and fittings - no issues. No hoses split or missing, but what I did find was a crack down the front side of the surge tank where it was welded. I removed the surge tank and fitted the lines back to original configuration and started the car. No problems.
My question is... has fitting a higher flowing pump to the tank unit caused this?? I initially thought that I'd wired the relay incorrectly but since refering to instructions ive found on this forum I realised I could have another issue. I wouldnt think that having the smaller capacity pump feeding the tank and the larger capacity pump feeding the rail would be a problem with hydraulic lock.
Can anyone offer any assistance??
I guess... for it to split the welds and NOT bust a hose is weird.
Although I've been using the same set up for a few years with no issues. I just hope the rest of the welds dont fail once I hook it up again.
Hi arronm
Yeah I did. I dug out an installation manual and on PW surge tank, the top two spigots are to and from the fuel tank, the third or bottom spigot is a return from the reg/rail and obviously the supply comes from the poled side of the bosch pump.
  • Moar Powar Babeh
  • Member For: 19y 4m 2d
Get in touch with Kev from process west. I'm sure he'd like to see the tank that failed.
If the weld was sound and the tanks had no external impacts/damage there is no way fuel pressure would be able to cause it to fail.
I spoke to Kev over the weekend but I didnt mention the break. I just wanted to clarify the 100% that it was plumbed correctly. Ive had it welded up already and ill hook it up again this weekend.
Fingers crossed that its ok.
