insanegrunt Member 22 Member For: 16y 5m 4d Gender: Male Location: Bundaberg, QLD Posted 14/03/17 03:33 AM Share Posted 14/03/17 03:33 AM First time out with the 275/40/17's MT ET S/S Radials and got a PB of 11.9 @ 121mph in my ZF FG XR6T But with a 1.99 60ft. Most 60ft times I've bene getting are 2.0 or 2.1 and can't seem to go past the 1.99 Any advice on how to drop my 60ft times? Got XYZ Coilovers in and set on soft front and rear Stall on foot and hand brake. Tyres on 18psi Cheers in advance! Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 3m 13d Gender: Male Location: Probably above atmospheric pressure Posted 14/03/17 04:35 AM Share Posted 14/03/17 04:35 AM (edited) Lots of boost on the line, don't hold it for too long or you overheat the box, and don't break your driveline hahaha. I'm too scared to put a set of slicks on. Best 60 footer I've gotten is 1.9 as well. Also "shallow stage" - stop juuuuuuuuuuust as the second staging light is lit up (when rolling forwards to stage). Makes a tiny bit of difference since the car can roll a tad before it is detected as moving by the equipment. Edited 14/03/17 04:37 AM by discostig 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,294 Member For: 16y 10m 27d Gender: Male Location: Melbourne Posted 14/03/17 04:41 AM Share Posted 14/03/17 04:41 AM if you want good launches with regard to shock-absorber softness then the front needs to be soft and the rear needs to be stiff. with regard to launching a ZF with 275 MT's: Left foot hard on brake, pull handbrake on, push throttle until it starts to creep a tiny bit, back off throttle a tiny bit so that it settles still and build as much boost as you're willing to hammer through the tailshaft... Then simultaneously drop the handbrake quickly, let off the brake and ease the throttle to 100% to minimize/prevent wheelspin. Experiment based on surface Link to comment Share on other sites More sharing options...
Ale Member 249 Member For: 13y 6m 12d Posted 14/03/17 05:35 AM Share Posted 14/03/17 05:35 AM 53 minutes ago, k31th said: if you want good launches with regard to shock-absorber softness then the front needs to be soft and the rear needs to be stiff. Can tell most of your driving is that of a keyboard...... 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,294 Member For: 16y 10m 27d Gender: Male Location: Melbourne Posted 14/03/17 05:43 AM Share Posted 14/03/17 05:43 AM ok, tell me how that process is wrong, then? You want the weight to transfer to the rear and push hard onto the surface where the MT's are stuck to and taking the power you're delivering to it... there's extra grip that the extra downward force (momentum mass over the rear axle due to the front lifting and the back staying still) gives to those tyres from a slightly wider contact patch with soft tyres means it can take more torque from the driveline Link to comment Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,438 Member For: 15y 2m 12d Gender: Male Location: Melbourne Posted 14/03/17 06:21 AM Share Posted 14/03/17 06:21 AM build more boost as long as the rest is right. I use a gauge to help me. if your good some guys use revs and time it how long they build boost to achieve what they want. I was the same always 60ft 1.9s/2.0s now im in the 1.6s practice Link to comment Share on other sites More sharing options...
insanegrunt Member 22 Member For: 16y 5m 4d Gender: Male Location: Bundaberg, QLD Posted 14/03/17 10:31 AM Author Share Posted 14/03/17 10:31 AM Thanks for the advice so far guys! I should mention I have a built ZF and built tailshalft. Link to comment Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,438 Member For: 15y 2m 12d Gender: Male Location: Melbourne Posted 14/03/17 10:51 AM Share Posted 14/03/17 10:51 AM my zf is stock with upgraded input shaft and I got a built tail shaft. you will be right then good luck Link to comment Share on other sites More sharing options...
winstor Member 611 Member For: 16y 9d Posted 08/04/17 01:51 PM Share Posted 08/04/17 01:51 PM (edited) Any advice for us manual plebs? Obviously practice, but anything else to keep in mind? My 60ft times are keeping me out of the 12s!!! Edited 08/04/17 01:51 PM by winstor Link to comment Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 3m 7d Gender: Male Location: WA, Perth Posted 09/04/17 05:16 AM Share Posted 09/04/17 05:16 AM Link to comment Share on other sites More sharing options...
