Blow off valve XR6T ( Newby ) UPDATE
cruiser
  • Member For: 17y 2m 17d
I got 202 missing the chair stopper from the 209 run prior so I beat you nyah nyah
Your record is no boost AND no fuel, I had fuel coz racecar
Edited by discostig
  • Member For: 7y 10m 30d
Hi guys
Latest to my small problem
It seems that the sound is coming from the IR Blow off valve
Both fast  and normal and take off from lights normal speed  it just not stop
Tried adjusting control on the side of blow off valve ( Does nothing ) So I would think the blow off valve is broken
The name on it is IR Blow off valve
It looks like an easy replacment
Question is this a good Blow off valve or should I replace with another ??
Question Where do I purchase
Question Can I install myself
Thanks again guys really appreciate your comments
Cheers Steve
Edited by Rab
Double posts and formatting
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 10m
Looks like a cheapie, but I don't know it, personally... you can tell if it's leaking if you just idle the car and there's air blowing out of that "trumpet" section, as it shouldn't be blowing any air out under vacuum/idle conditions.
Get a stock one and put it in there, if necessary.
Yes, you can install yourself if you have the right tools to get the clamps on the hoses undone/done-up.
  • Site Developer
Yes, stock XR6T's have a "re-circulation" valve, which is a form of blow-off valve that recirculates the waste air back into the air intake instead of releasing it to atmosphere like the aftermarket one you have.
You can get one from a wrecker (cheaper) or Ford (more expensive). It's the same BOV for BA/FG. Or you can buy another aftermarket one (more expensive than Ford)
  • To Loud
  • Member For: 13y 2m 11d
I might be wrong here, so please correct me if I am wrong.
In that picture it looks like the adjustment screen can be tightened up to recirculate the air back into the system instead of ventilating to the environment.
Do all Blow off valves do this?
If if you tighten the screen does the sound of a boost leak actually reduce?
  • To Loud
After doing a bit of a search, I found this
https://www.neon-technologies.com.au/products/dual-port-blow-off-valve-bolt-on-for-audi-s3-a4-a6-s3-and-tt
Seems like it is a dual port blow off valve. So if it does recirculate and the OP does turn the screen to harder, will he still hear hear it as much if it is recirculating?
  • XR50T
  • Member For: 11y 9m 9d
With dual port bovs the two outlets are staggered so the recirculating side opens before the externally vented. So if its working as it should when cruising it will be quiet and when you be smashn the boost she'll be loud AF.
