Bretthawk89 New Member 11 Member For: 9y 10m 14d Gender: Male Location: Adelaide Posted 05/03/17 05:50 AM Share Posted 05/03/17 05:50 AM Hi all, I've been a member for a while now and read lots of information about lots of different things which has been most helpful. But this is my actual first post so be kind and any help will be appreciated ? Ok so I have a 06 bf xr6t zf 6sp. My speedo and odometer isn't working and the car won't rev past 4K rpm. I took it to a reputable tuner on the 8th of February for a retune after installing a couple more engine mods and I got it back from the tuners a couple weeks ago and they said they couldn't fix it so I'm giving up hope on them and going to try fix it myself. My dash is showing an engine check light and x4 flash tuner is showing 2 codes P0500, U1039. ive checked the batter voltage, it's 12v when cars off and 14v when on so I assume my battery is ok. ive checked and cleaned all 4 abs sensors at each wheel, they where seriously filthy so at least they are clean now and I assume they should be ok considering there's no abs illuminated on the dash. what else could it be? I'm thinking it might be the cluster but I don't want to be just guessing and buying things unnecessarily especially if there's a way to pin point the problem? Link to comment Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 2m 20d Gender: Male Location: WA, Perth Posted 05/03/17 06:41 AM Share Posted 05/03/17 06:41 AM I am no specialist, so take this with a grain of salt. Also most of the falcon whisperers are at racewars this weekend. Hopefully they will all be back home tomorrow and you might have a better answer then. I have been here that long and I am not sure if this is allowed. anyways, one of the bookmarks I have is on the australian ford forums. http://fordforums.com.au/dtc/dtc.php I went there and checked your codes. P0500 seems to indicate an issue with either your cluster, sensors or pcm. U1039 seems to indicate damaged wiring, so that could be the cause of your p0500 code too.... check the website out for all the results. anyone else out there with ideas? Link to comment Share on other sites More sharing options...
Bretthawk89 New Member 11 Member For: 9y 10m 14d Gender: Male Location: Adelaide Posted 05/03/17 08:33 AM Author Share Posted 05/03/17 08:33 AM Thanks for the reply mate. so what I read on the p0500 code is that the pcm receives the vss from the cluster? If that was the case would it be true that I could test the vss wire that goes to the cluster? If only I knew which wire ? As for the u1039 code I dont understand what SPC, IC and DLC mean.. im guessing it's either the cluster or the tuners done something wrong because the speedo was working fine before it went in. do you know if clusters are normally reliable? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,242 Member For: 16y 10m 9d Gender: Male Location: Melbourne Posted 05/03/17 08:36 AM Share Posted 05/03/17 08:36 AM if the speedo and odo were working before the tuner touched it, then take it back and force them to fix it or find somebody who can fix it. Link to comment Share on other sites More sharing options...
Bretthawk89 New Member 11 Member For: 9y 10m 14d Gender: Male Location: Adelaide Posted 05/03/17 08:47 AM Author Share Posted 05/03/17 08:47 AM k31th- I'm waiting to hear back from someone to get it retuned/speedo fixed but he can't get me in for a couple weeks. So I figured I'd do what I can in the mean time. as for my old tuner I live over an hour away and have had a seriously sh*t experience with them and aren't wasting anymore time with them. Link to comment Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 2m 20d Gender: Male Location: WA, Perth Posted 05/03/17 09:38 AM Share Posted 05/03/17 09:38 AM Who are they. Let us know so that others on here don't go down this path. I think you should have a chat with @JETURBO and get your car tuned too. Link to comment Share on other sites More sharing options...
ROB83R Member 1,632 Member For: 8y 9m Gender: Not Telling Location: Radioactive wasteland Posted 05/03/17 12:54 PM Share Posted 05/03/17 12:54 PM Definitely pm @JETURBO he's the gun near you. You can pm me who you took it to. There's a couple good shops near you that I don't think would have that attitude with you. Definitely sounds like they've damaged something while in their care. Link to comment Share on other sites More sharing options...
Bretthawk89 New Member 11 Member For: 9y 10m 14d Gender: Male Location: Adelaide Posted 05/03/17 07:45 PM Author Share Posted 05/03/17 07:45 PM @jeturbo is the guy I'm waiting to hear back from ? I'd prefer not to say who I took it to on a public forum or at least until my cars going so I can share both the good and bad experiences. But yea other people from this forum have recommended them and had good results, I guess I'm just unlucky! I mean there isn't many places here in Sa to take it to, it wouldn't be hard to guess. Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 8m 19d Gender: Male Location: Adelaide Posted 05/03/17 09:43 PM Share Posted 05/03/17 09:43 PM Hey Hey ... someone tag me in here lol looking forward to fixing her up for you Brett but to start I must say I'll be looking at the system and the fact the first "Mechtronics" unit in your ZF was "fried" the first time in went in and a new unit had to be installed, simply the VSS comes out of the ABS module via the wheel speed sensors ( that you've already cleaned up ) and all of these inputs/outputs talk to the ZF/ECU the fact your car is drive able suggests the wheel sensors are feeding a signal into the ABS and a VSS is working to some degree as the car wouldn't play the game if it didn't have the basics going on there's a potential for broken or damaged wiring for sure but a connector might just be not fully "home" yet, yes the speedo cluster could be stuffed but we will have to work it out as if the first shop has "Fried" thefirst mechtronics unit (who knows why or how) but it might be a follow on from that event either way sounds like fun .... 1 Link to comment Share on other sites More sharing options...
joe@cms Member 129 Member For: 15y 8m 4d Gender: Male Posted 06/03/17 01:06 AM Share Posted 06/03/17 01:06 AM ok my 2 cents worth & seeing this many times over & over again if its a BF ZF & you intermittently lose speedo, ABS & traction control lights with wheel speed codes replace the ignition coils with genuine ford coils then see how you go 2 Link to comment Share on other sites More sharing options...
