Wranglerfpr000 New Member 20 Member For: 8y 6m Posted 23/02/17 05:29 AM Share Posted 23/02/17 05:29 AM Hey all, Since installing my gauges and taking the ICC out and completing the job....gauges working beautifully however....my ICC and cluster dead. The cluster has lights n warnings however tacho etc not working except fuel and ICC is completely dead.... YES the plug on the back is reset everytime I go to re-install the ICC but still no communication to them... the first couple of times I had icc work but no cluster...or cluster no ICC....now cant get either...im bout to burn the F@&kin thing. Can anyone suggest anything??? Iam pretty mechanically minded and electrically minded too....but im friggin stumped.... I didn't think we had to re-tune the ICC to the BEM? do we? Link to comment https://www.fordxr6turbo.com/forum/topic/92955-icc-and-cluster-not-working-over-it/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,452 Member For: 17y 21d Gender: Male Location: Melbourne Posted 23/02/17 05:32 AM Share Posted 23/02/17 05:32 AM sounds like you've either bent and shorted some pins on the plug point on the back of the ICC or you've "let the smoke out" of the electrical circuit board(s) in the ICC. I'd suggest getting a replacement ICC and/or BEM module. Link to comment https://www.fordxr6turbo.com/forum/topic/92955-icc-and-cluster-not-working-over-it/#findComment-1632615 Share on other sites More sharing options...
Wranglerfpr000 New Member 20 Member For: 8y 6m Posted 23/02/17 05:33 AM Author Share Posted 23/02/17 05:33 AM All the pins are straight....have been the whole time The A/C works fine its prob on Auto but no buttons, no screen etc... :( Link to comment https://www.fordxr6turbo.com/forum/topic/92955-icc-and-cluster-not-working-over-it/#findComment-1632616 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,452 Member For: 17y 21d Gender: Male Location: Melbourne Posted 23/02/17 05:49 AM Share Posted 23/02/17 05:49 AM certainly sounds like you've shorted/blown something in the ICC display circuit board and it must be sending back a "broken" signal to the BEM which may cause those fluctuations in voltage which can cause things connected to the BEM to either not work at all or work improperly (e.g. the instrument cluster) Send the ICC over to somebody like ASL for repair/replacement or get a replacement ICC from a wrecker (use your existing BEM with the new ICC otherwise the car won't start) Link to comment https://www.fordxr6turbo.com/forum/topic/92955-icc-and-cluster-not-working-over-it/#findComment-1632618 Share on other sites More sharing options...
Wranglerfpr000 New Member 20 Member For: 8y 6m Posted 23/02/17 05:51 AM Author Share Posted 23/02/17 05:51 AM Ah ok no worries.... so the current BEM will plug into another ICC without having to program it? Link to comment https://www.fordxr6turbo.com/forum/topic/92955-icc-and-cluster-not-working-over-it/#findComment-1632619 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,452 Member For: 17y 21d Gender: Male Location: Melbourne Posted 23/02/17 05:52 AM Share Posted 23/02/17 05:52 AM that's correct Link to comment https://www.fordxr6turbo.com/forum/topic/92955-icc-and-cluster-not-working-over-it/#findComment-1632620 Share on other sites More sharing options...
Wranglerfpr000 New Member 20 Member For: 8y 6m Posted 23/02/17 05:57 AM Author Share Posted 23/02/17 05:57 AM Ok, thanx mate.... looks like im gunna have to source another dual zone prem ICC then Link to comment https://www.fordxr6turbo.com/forum/topic/92955-icc-and-cluster-not-working-over-it/#findComment-1632621 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,452 Member For: 17y 21d Gender: Male Location: Melbourne Posted 23/02/17 05:58 AM Share Posted 23/02/17 05:58 AM yep; good luck with your search and hopefully it's not too expensive Link to comment https://www.fordxr6turbo.com/forum/topic/92955-icc-and-cluster-not-working-over-it/#findComment-1632622 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 6m 4d Gender: Male Location: Perth Posted 23/02/17 07:02 AM Share Posted 23/02/17 07:02 AM Are the plugs in the rear of the cluster all the way pushed in ???? Link to comment https://www.fordxr6turbo.com/forum/topic/92955-icc-and-cluster-not-working-over-it/#findComment-1632623 Share on other sites More sharing options...
Wranglerfpr000 New Member 20 Member For: 8y 6m Posted 23/02/17 07:04 AM Author Share Posted 23/02/17 07:04 AM Yeah as far as I know I'll double check....could that be fouling the Icc too? Link to comment https://www.fordxr6turbo.com/forum/topic/92955-icc-and-cluster-not-working-over-it/#findComment-1632624 Share on other sites More sharing options...
