Fg Offsets And Tyre Questions
Dillz
  • Member For: 14y 2m 7d
So offset decreases when the number increases? So +40 is less than +30?
And is offset in mm? Seems stupid using metric and imperial concurrently.
When you increase run width, does it automatically alter the offset by a standard amount? Say of you went from stock 18" to stock 19", does the offset change?
  • Turboless
  • Member For: 13y 11m 30d
Yep +40 is further into the middle of the car than +30.
Yep one of the wheel whores, jd or worm told me its in mm.
Understand it all, just the only thing I don't get is changing rim width. They just know what offset would work straight up lol, baffles me.
So for example 8.5in +30, if changing to a 9.5in, to get the same offset, would it be +18? I come to that offset because 1in is 25mm..so half inch (12.5mm) bigger each side (inside/outside of rim), so 30-12=18.
Correct jd or worm? Or wrong?
  • Member For: 14y 6m 30d
haha yeah kinda shy, that will make it the same on the inside of the car and poke another 25 mm outside the car
8.5 +30 would be 9.5 +43 and be the same on the guard side
think of it like this
if you had 8.5 and 9.5 both plus 30, the 9.5 would stick out 12mm more (because 1 inch 25.4mm so split 13mm each side) so you need to make offset less to bring the outside of the rim inwards , so +43 bring it back towards the strut side
Edited by j.d
  • Member For: 16y 11m 6d
^^ reading that headf*cked me. But that's how it works.
  • Turboless
Ahhh yep yep I went the wrong way lol. Thinking of it now dno why I'd make the bigger rim further out haha. Thanks jase :spoton:
Lol, yeah thought that might happen, doesn't help I said 12mm once and then 13mm the other time lol but I can't edit now,
  • 777
  • Member For: 16y 25d
So technically if I want to go to a 10.5" rear rim and I am currently on +35 I should be looking at a +42?
  • Idiot Member
  • Member For: 15y 1m 5d
Ive got +40 9.5 with a 285 and there is no more room to the lower arm on the inside.
